Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Mentors & Apprentice Locator
Mentors & Apprentice Locator Looking for mentors and/or for apprentices in your own locality please post your info. Do not post any personal info address, phone numbers etc.
Old 06-25-2008, 10:02 PM
tac8357 is on a distinguished road
Feeds and Speeds
I kinda new to job shops where everything is based on speed of production. There looking for a average rate of between $45 and $65 and hour per Haas. I got 2 years of MasterCam programming building mostly welding fixtures. Then was layed off with most of the tool room. Now I've been working with Gibbs for the milling stuff for almost a year now and they just bought Feature cam for the Lathes. I'm finding it a ***** to run production at speed where they make that kinda of per hour. Its mostly hit and miss and i follow the tooling feeds the recommend. We mostly us SGS Z Carbs ,V carbs, Seco Turbo mills , OSG Drills. Anyone got a magic bullet . Need some help. I know how to make things right and of good Quality now i got to make the machines earn there keep.
Old 06-26-2008, 10:50 AM
JDenyer232 is on a distinguished road
Well you can use the recommended speeds and feeds, and then adjust up a little at a time until you break the tool, or sacrifice tool life then back off a little. Look closely at your programs to see if you can eliminate any rapid moves that you don't need. You may find several to ten of seconds in uneeded rapid moves. 2 seconds doesn't seem like a whole lot, but on a 2000pc run it adds up to over an hour of saved time. Use a fixture that allows you to run multiple parts whenever you can, here is why. If you have a ten tool program, then to make six parts you need to perform a tool change 60 times. Run them in groups of six and you can have each tool perform its op on all six parts then change to the next tool. The result, 6 parts done with only 10 tool changes, saving you 50 tool changes. On our machine we can be chip to chip in 3 sec, this saves 2.5 minutes for every 6 parts made. On a 600 part run you will save just over 4 hours just changing tools! Hope this is of some help.
Speeds and Feeds frogger Haas Mills 20 02-26-2008 03:42 PM
Feeds and Speeds sjotime! Mach Software (ArtSoft software) 1 02-17-2008 04:46 PM
Help! with Feeds and speeds please! sjotime! Visual Mill 3 02-13-2008 01:56 AM
Speeds and Feeds wdp67 Benchtop Machines 2 07-10-2007 03:06 AM
feeds and speeds lito General Metalwork Discussion 4 03-14-2005 08:58 AM
