ISO Mentor/Consultant In NE PA (Poconos) CNC/Router/Plasma
Results 1 to 4 of 4
Thread: ISO Mentor/Consultant In NE PA (Poconos) CNC/Router/Plasma
    Jan 2014
    Default ISO Mentor/Consultant In NE PA (Poconos) CNC/Router/Plasma
    I take delivery of a Mogul CNC kit this Tuesday (1/28). If you can help or just want to learn with me, come on down, son!
    I'm building the CNC table now and will have my small shop re-configured for the CNC by this time Monday.
    Steve
    Feb 2014
    Default Mentor around Albrightsville,pa.
    Hello Steve, did you find help in the Poconos ?I am in Albrightsville on 115 and have a hobby router machine ,looking for someone to help me . I have cut a few things but am having trouble converting line drawings to cad/cam .
    Steve R.
    Jan 2014
    Default Re: Mentor around Albrightsville,pa.
    Hey Steve, sorry for slow reply. I got pulled away from the CNC project, but I'm on it full-time now. I have a pretty good idea where you're located. I should be able to help you with graphics prep. What graphic programs are you running (include version)? post-processor? I mostly use Corel and Adobe Illustrator/Photoshop > Sheetcam (Plasma) > Mach 3. I'm a CNC newbie but have extensive graphic design/digital graphics experience. The DXF file format works well, but not all versions work in all post-processors. I tested several output versions until I found the one that worked. For example via Adobe Illustrator > Export > DXF > output version pop-up noting AutoCAD Version option (see graphic)ISO Mentor/Consultant In NE PA (Poconos) CNC/Router/Plasma-screenhunter_63-may-28-13-45-jpg
    Steve
    Member AMG Guitars's Avatar
    Jan 2010
    Default Re: ISO Mentor/Consultant In NE PA (Poconos) CNC/Router/Plasma
    Steve, I live in the Pocono's.
    With your graphics experience it shouldn't be a problem to create relief carvings from heightmapped grayscale images. This is a simple thing actually and you can make some really cool carvings. The key to it is with the photo. If you can photoshop a picture into a greyscale heightmap, I can show you how to turn it into a carving.
    Attached Thumbnails Attached Thumbnails ISO Mentor/Consultant In NE PA (Poconos) CNC/Router/Plasma-tigergaoguang-jpg
