Results 1 to 6 of 6
Thread: E/G mill design
    Apr 2009
    UK
    E/G mill design
    Hello, I have posted a few times already about this in the E/G thread with some helpful replies, but was recommended to make my own.
    Here are some pictures of the design I had come up with:
    http://img714.imageshack.us/g/cncv3c.png/
    Quote Originally Posted by RotarySMP View Post
    I think you would be better off making your own thread for this specific build. It will likely disappear into obscurity on his monster thread.
    HTD (the rounded tooth form) toothed belts and pulleys are supposed to be back lash free.
    Have you a plan for how you are going to get rails on two sides of two separate monoliths parallel and aligned? Four vertical surfaces that need to be parallel and aligned, but can not be cheaply ground after the uprights are mounted to the base does not seem like a practical solution.
    If you are planning to use the common E/G method of casting steel mounting rails into the E/G, and then having precision interface surfaces for the Linear bearings ground after it cures, you would seem to be making it very differcult for yourself.
    Remember the engineering adage "anyone can design complicated, it takes genius to design simple"!
    If you put the Y axis onto the gantry cross beam, with both it's rails on one face, and then mount Z off Y, you will have a much simpler ($$$$) job getting precise alignment.
    Thanks for the comments rotary.
    The only reason for me wanting the Y-axis on the Z-axis is so I can have a large amount of travel for the Z, and without restricting the other two axis I can think of no other way.
    I decided to change the design because of your comment about lining the 4 rails, I have no idea how I would do it accurately other than getting it ground afterward or maybe use some adjustable mounts but I don't think that would be very accurate.
    Here are some pics of my new idea: http://img708.imageshack.us/g/cncv4c.png/
    I have styled it after this picture posted by BobWarfield in another thread
    Jul 2003
    california
    are you going to use linear bearings or are you going to implat steal and then grind or scrape them?
    Apr 2009
    UK
    I plan to cast ground steel or aluminum into the E/G and then mount linear rails to them.
    Sep 2005
    Indonesia
    Hello afaik,
    Are u trying to make gantry mill? Have you started yet? Post some picture here. What controller you use. I also plan to make this big gantry mill.
    Apr 2009
    UK
    asuratman
    I plan to make the mill yes, I wont be starting to make it until the design is OK, I'm kinda waiting on others to see what they think as I've never worked with E/G before.
    Sep 2005
    Indonesia
    If you look on this gantry, its gantry is on the back of x axis. What do you think the advantage of this position compare to position it in the middle of x axis? My plan is to pu gantry in the middle of x axis. Thanks.
    1. CNC Mill Design
      By MattP in forum Open Source CNC Machine Designs
      Last Post: 09-30-2008, 12:18 PM
    2. Newbie- CNC Mill Design
      By yngndrw in forum General Metal Working Machines
      Last Post: 04-05-2008, 12:35 AM
    3. Unorthodox CNC Mill Design
      By Zach_G in forum General Metal Working Machines
      Last Post: 05-26-2007, 01:06 AM
    4. help with CNC Mill (design)
      By bigtonyicu in forum General Metal Working Machines
      Last Post: 10-18-2006, 11:32 AM
    5. CNC Mill Electronics Design
      By apollo in forum General Electronics Discussion
      Last Post: 04-14-2004, 08:57 AM
