Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 04-12-2005, 06:34 PM
smarbaga is on a distinguished road
shaft size
hello all
question ???
i have 2 - 1" dia. shafts, 44" long. (thompson)
i plan on supporting them with 2 supports at each end, 3" apart.
putting 2 linear bearings 6" apart on each shaft.(dual pillows)
how much weight do u think the combined shafts will carry,
before they start to sag.
thank you all, in advance for your advice
sincerely smarbaga
Old 04-12-2005, 10:01 PM
2muchstuff is on a distinguished road
There is a beam boy calculator that has been mentioned in the forums before. I have never used it before but maybe it will have what you are looking for http://www.goecities.com/richgetze/
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 04-18-2005, 07:00 PM
thanks 2muchstuff but my computer says the the page can not br found
smarbaga
Old 04-18-2005, 08:55 PM
If I could spell, I'd be dangerous. Try this http://www.geocities.com/richgetze/
Old 04-19-2005, 06:37 PM
yepper its beamboy .... thats the ticket
thank you very much 2muchstuff
ps:good thing i re-read this ,,, cause i spelled your name wrong
Old 04-19-2005, 10:39 PM
Glad it worked out for you. I wish that I could down load it. Ever since I down loaded that service packII for Windows XP, my computer wont let me do a lot of things and I'm afraid to dig into it to find the problem because I might screw something else up. You know, Murphy's Law.
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
mounting flexible couplings to 17mm shaft cowanrg General Metalwork Discussion 14 04-11-2005 01:40 AM
Ballscrew size -vs- project size Alan T. CNC Machining Centers 4 10-18-2004 09:53 PM
Thompson Shaft and bearings flex help? foamcutter DIY-CNC Router Table Machines 9 04-24-2004 05:24 PM
My huge shaft! kong DIY-CNC Router Table Machines 4 08-29-2003 01:54 PM
