| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| Question obout acme threaded rod (lead screws) Looking at the McMaster Carr Online catalog for some Acme Screws and Nuts and I am a little confused about the # of starts for the screws. Question - The catalog states that a screw with more starts will move faster than a screw with less starts. Can you asssume that a 5 start screw will move 5 times as fast as a single start screw? Will a normal acme nut work on any lead screw no matter what the # of starts? Thank you.
__________________ Check out what I am working on at www.routerbitz.com! |
| Yes, a five start screw will move 5 times faster than a single start. No, a single start nut will not work on a five start screw. It would be like trying to put a 1/2-20 nut on a 1/2-13 shaft. I read in another post of yours that you were trying to change from a 1/4-20 screw? If cost is a problem or you just like to scrounge up stuff, try a lead screw from a garage door opener. They come either pieced or in a 7' solid length. Find a company that services/installs them and ask them for one that they have pulled out, or root thru their dumpster. They are usually about 5/8" in diameter with an Acme thread.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| Ball screws, Acme screws, threaded rod | DJ Morrow | DIY-CNC Router Table Machines | 11 | 03-22-2007 01:39 PM |
| What Acme threaded rod to get? | CNC Darren | DIY-CNC Router Table Machines | 7 | 09-29-2004 07:14 AM |
| Acme threaded rod use | Apples | DIY-CNC Router Table Machines | 6 | 05-12-2004 01:54 AM |
| wow on the enco acme threaded rod | mhackney | DIY-CNC Router Table Machines | 13 | 03-02-2004 09:32 AM |
