Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 11-21-2009, 07:34 PM
captainDL is on a distinguished road
Need Advice on material!
Hi everyone. I am going to be making a set of connecting rods for my snowmobile engine. I need a shorter center to center distance so off the shelf isn't possible. My question is: If I machine these from 4140 should I have them thru hardened and tempered, or should I make them from a material that can be case hardened? The bores need a hard surface because they act as races for the needle bearings. Any info./ advice would be appreciated.
Old 11-22-2009, 12:17 PM
Look up specs on 8620. Good toughness and case hardening characteristics.
I don't know the reasoning for the cc shortening, but I hope you considered the effect on balance and harmonics. If this is a 2-stroke engine, the high engine rpm potential can put you into "shattering mode". Somewhere there is a bunch of clutch parts orbiting the earth. I've never determined where they landed or if they ever did. LOL
Dick Z
DZASTR
Old 11-22-2009, 02:20 PM
aaron p's Avatar
aaron p is on a distinguished road
8620 and 8740 are good materials to look at.
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
Old 11-24-2009, 04:00 PM
BillTodd is on a distinguished road
Not an answer to your material question, but I have heard of con-rods being shortened in a press with a little local heating and some care to keep things straight. (apparently it was common practice when 'stroking' and engine to larger capacity)
Bill
Old 11-26-2009, 11:52 PM
Bill Johns is on a distinguished road
Rockwell 38 to 40 C scale, you don't want the whole rod case hardened. I'm not sure what the hardness for the needle bearings should be, you would want to just harden the
bearing surfaces.
Old 11-26-2009, 11:56 PM
aaron p's Avatar
Ive never ever heard of this. Im around high end race engines all the time and went to school for race engine theory and machining. Putting a rod in a press would make the big end and small end out of round where the wrist pin and rod bearings go.
Old 11-27-2009, 07:45 AM
Obviously care has to be taken not to squash the ends
A couple of mandrels in the ends and a bit of local heating to soften the rod in the middle would reduce the load on the ends enough I think.
Bill
Old 11-27-2009, 07:41 PM
Thanks for all the advice so far. So what I'm understanding 4140 isn't a good choice? I only need to harden the races not the entire rod. 8620 may be a better option. Will 4140 case or flame harden in the bearing area? I know most aftermarket rods are made from 4340 and forged, but I can't find 4340 in flat stock and forging isn't really feasible for a single set of rods. Just want to have the best chance of having long lasting rods.
Need advice on injection material originator Moldmaking 9 06-29-2009 09:03 AM
Material Advice please ImanCarrot General Metalwork Discussion 7 11-20-2007 03:53 AM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 08:03 AM
An interesting material - need advice DAB_Design Composites, Exotic Metals etc 9 09-19-2005 06:39 PM
Material ID DLMACHINE General Metal Working Machines 1 02-24-2004 08:58 AM
