| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Could someone please explain the paragraph below in a for dummies explanation for me please as i have no understanding of this please see below? The place to start is to determine the load torque in oz/in. Be sure to include the torque necessary to accelerate the load. Next come up with the maximum speed the application has to operate at in full steps per second. Multiply the two together and then divide the result by 4506 to calculate the power in watts necessary to meet the application requirements. Pick a motor at a power supply voltage that provides a 40 percent reserve power margin above your requirements |
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Torque is the amount of force required to turn a shaft. It is expressed in oz-in or ft-lbs or fig-newtons or some other measurement that involves a weight and a distance. Turn your crank handle so it is parallel to the floor and start putting one ounce weights on the end of the handle. When the handle turns, multiply the number of ounces used by the distance from the center of the shaft to the place you attached the weight. Your result is oz-in of torque required. Now to figure power. Count the number of turns it takes in one second to move the table at the desired speed. Multiply this by the number of steps per turn from the stepper spec. Now take this figure, multiply it by the torque found above and you should be on your way. Not sure where the 4506 comes from but is probably calculated using some formula involving the power you just found. Hope this is not too basic for you but nowadays the schools don't bother to teach basic physics and instead are concentrating on putting condoms on cucumbers.
__________________ I used to be appalled, now I'm just amused. |
Many thanks Pat |
| I have never used steppers so far in any application, but I know the Kollmorgen sizing software referenced to in the link includes steppers in the selection process, I know that both servo's and steppers in the software is geared to the Kollmorgen line, I usually just use it as a guide line when selecting a motor for a particular application to get a rough motor load inertia match. Over time I have come across alot of info off the manufacturers sites, and downloaded considerable information, which I found was a fortunate habit as many sites have changed and no longer appear to offer the same info anymore. e.g. Sanyo Denki had an excellent Handbook of Servo Systems on their site which no longer exists. The moral is, if you see it, save it. Al.
| Hi, Sure' If you need any help to read Mechanical Engineering. just visit Freelancer.com There you can find thousands of coders who are really very helpful on Mechanical Engineering. And use this unique 'NUTSANDBOLTS' word to get some extra feathers. Have a nice time bye |
| Thanks Al Yes steppers are given treatment and included in the site you gave the link for along with a lot of data on encoders and servos - a first class refference and I have now saved as much as I think is relevant. Thanks again Pat |
| Murphy Bed Router - concept | jcoats | CNC Wood Router Project Log | 7 | 01-25-2009 03:12 PM |
| Emco Concept turn 55? | praetor | Vertical Mill, Lathe Project Log | 0 | 06-08-2008 01:18 AM |
| Need comments on design concept please | Jester966 | Benchtop Machines | 5 | 02-25-2007 08:12 PM |
| Taig 4th Axis Concept | nattyone960 | Taig Mills & Lathes | 0 | 11-17-2006 04:02 AM |
| Concept Z axis | duluthboat | DIY-CNC Router Table Machines | 46 | 01-26-2004 08:42 AM |
