Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 03-21-2005, 12:57 AM
Ursine is on a distinguished road
Bearing Arrangements
In my research (lurking) I've seen at least 3 different SIMPLE arrangements using skate bearings and gas pipe. There are surely more. Please add to this list.
Thanks,
Dave
Old 03-21-2005, 04:31 AM
andy_ck87028 is on a distinguished road
Hi
This is a variant on one of your thumbnails where two angle irons have been placed next to each other with skate bearings between (and unseen on this picture but definitely there). The assembly pictured therefore has a total of 6 skate bearings. When rotated on the pipe by 45 degrees from the horizontal, they provide support and locking control both up, down and sideays lateral.
Very cheap to make and they slide beautifully.
Andy
Name:	x axis assembly.JPG‎
Old 03-21-2005, 06:24 AM
ger21's Avatar
My design supports the pipe. The pipe is attached to the table (and gantry) and the bearings are held tight to the pipe by sing threaded rod to keep everything tight, in compression. It's not finished yet, but I've had the gantry assembled and it seems to work very well.
Another First Router
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Torsion box and Skate bearing thought spalm Linear and Rotary Motion 0 06-03-2005 04:19 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 05:52 PM
Ball screw angular contact bearing block dowling177 DIY-CNC Router Table Machines 0 03-15-2005 03:03 AM
Pressing a miniture bearing into 6061? kumaichi General Metalwork Discussion 6 01-04-2005 02:24 PM
