Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 11-04-2009, 06:52 AM
Nigel Thomas is on a distinguished road
Load calculation
How do you calculate the sizes of square section EN8 mild steel bar to be used to pick up a load, if I know the weight of the load and the length of the bar. I need to lift a 1 ton injection moulding tool with a bar of 400mm length. The bar is bolted to the top of the tool at both ends and an eye bolt is secured to the middle of the bar. Both eye bolt and fixing bolts are 16mm. I know I have to build in a safety factor of about 4 to 1 so I really need this bar to lift 4 ton.
Any thoughts would be appreciated.
Old 11-04-2009, 10:24 AM
wildwestpat is on a distinguished road
Hi Nigel
You need to be compliant with the UK HSE regs if this work is in the UK. The regulation is known as LOLER:- http://www.hse.gov.uk/pubns/indg290.pdf
You will note that the certification as safe to lift has to be done by a competent person. As with much of the HSE regulation that has been interpreted by the courts and will probably mean a qualified member of one of the recognised engineering institutes with a specialism in stress calculation.
Calculation formulae can be found in 'Roark's Formulas for Stress and Strain' and in the Machinery's Handbook.
Stay safe
Regards
Pat
Chip load/feed per tooth calculation TravisR100 Haas Mills 10 07-21-2010 02:32 PM
Need Help!- calculation biotec Stepper Motors and Drives 2 04-20-2009 02:26 AM
Need Help!- Deflection Calculation Freff DIY-CNC Router Table Machines 13 11-05-2008 08:40 PM
oz-calculation help needed methuso Stepper Motors and Drives 3 09-25-2007 10:39 AM
resistor calculation need help mike10 Stepper Motors and Drives 2 03-29-2005 10:21 PM
