| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
I've got a linear bearing situation where an extension spring will have about 500 pounds of force pulling on it. The linear bearing can adjust up or down to increase or lessen the force of the spring. I was wondering if anyone can tell me if a 3/8" Diameter 316 Stainless Steel Shaft can handle the amount of force or it will bend. See the pic below for an example. |
| every thing bends under a load, how much deflection will you tolerate? I am not an engineer, just read the books for fun (yes I am very strange), I just looked it up and did the math and I calculate that the deflection at the center of the rod is about 0.00483". Is there an real engineer to back me on this? (500 x 2.342^3) / (48 x 28,500,000((pi x .375^4) / 64))
__________________ cadfish http://www.burgiengineers.com/ |
| Well, thanks. So you're saying that for 500 pounds of force on a 3/8" Stainless Rod that is 2.342" long the deflection is 0.00483"? That's not bad, I think that would work. I guess my question really, which I didn't explain, is would 500 lbs bend this rod permanently? If the deflection would not hinder the linear bearing from sliding I would say it's a go? |
| From what I understand is that once it passes the yield point it will not return to shape. The yield point for SS316 is 35,000psi and SS316L is 30,000psi. I am thinking its a go. But I could do the math later and see how much stress it will actually have.
| uhh ohhh, I calculate the max stress as 56515.444, (500 x 2.342) / (4 x .00518) Is there a professional engineer who can give us an answer?
| I was just doing some research and Mcmaster has some 17-4 Stainless which has a yield strength of 118,000 PSI, that should do, right? Here's a link. http://www.mcmaster.com/#9095k107/=4c87ow Cadfish, is there a page somewhere where I can read about how to calculate what you are calculating for me? Thanks. |
| Do you have a Machinery's Handbook? They have about 300 pages with these formulas and properites of materials they even give sample problems explaining how to use the formulas. If not you can try this. http://www.engineersedge.com/beam_be...m_bending2.htm They have an explanation explaining the terms bellow.
#10
| When I calculated, I use a formula from any stress and strain text book. I use a two bearing supported shaft. The formula for the max deflection at the center is dx=(PL^3)/(48EI). If you change the steel, the modulus E will not vary a lot, you will not gain much using another steel. I you want less than 0.004 I suggest to increce the diameter of the shaft. |
| Need Help!- Jog Handle Inop?? | JoBwan | Mazak, Mitsubishi, Mazatrol | 12 | 09-30-2009 06:27 AM |
| EZ Trak Handle | gripper | General Metal Working Machines | 0 | 04-08-2008 08:22 AM |
| Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft | DonW | DIY-CNC Router Table Machines | 7 | 03-17-2008 04:58 PM |
| Jog Handle | Rudee | Fadal | 1 | 05-04-2007 11:33 PM |
| Knife Handle | wjbzone | WoodWorking | 0 | 08-17-2005 12:10 PM |
