| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| Ok I know they make a crankshaft grinder lathe but I can't seem to find a old one and new equipment is way out of my price range, I have heard years ago you could buy a crankshaft grinder attachment for the old atlas/craftsman lathes (can't find any of those either) Here is my question : has any one every made a grinder attachment for say a 6"x36" metal lathe or is it even possible? if you have would you mind sharing some detailed pictures and any plans/draws yo may have so I could try to build my own |
| Goldhunter 2, What size crankshafts? (total swing, off-center throw, length). There are used crankshaft lathes and grinders on the used machine sites on the internet. Try surplus machine tools etc. Dick Z
__________________ DZASTR |
| Goldhunter 2, I have alot of experience with crankshaft grinders and lathes. If you have a lathe then you have approximately 15% of a crankshaft grinder. If you have to ask about the other 85% then you have not done you homework. RFB |
| Richard, all the cranks I would mess with are 4 or 6 cyl , 24" or 35" total length strokes are normally 3.87" , 4" , 4.25" witch I figure I need a min of 6" swing for plenty of clearance I have found several sites or adds for used crankshaft grinders (well out of my budget ) but these are mostly larger machines for more of a commercial application I need something on a smaller scale mite only do two or thee airboat cranks per year I don't care if its a little slower process then is commercial acceptable now either that is why I was thinking of the old atlas attachment I read about but have not even found a picture of one of those yet RFB, well your probably right I need to do research that's why I am asking questions , I may be hard headed sometimes but I have learned it is cheaper to ask ahead before lessons get expensive . seeing one in person would help greatly but unfortunately everywhere around here sends them off so there is no grinders for me to see in person, maybe you could point out where to do my "homework" for small crankshaft grinder attachment |
| Goldhunter 2, Rotating the mass of a crankshaft alone isn't that difficult. The crankshaft must be off-set equal to the radius of the crank throw to be ground. This is usually accomplished with a set of fixtures. Added to the fixtures are counterweights to off-set the off-set weight of the crankshaft. The size of the loaded, off-set, counter-weighted fixture generally requires a fairly large swing OVER THE CROSS SLIDE engine lathe. For limited production, a large swing old HEAVY DUTY lathe with a grinding attachment should be able to fill your requirements. This ASSumes you have the room and available power to hook this up.LOL Being a bit of a motorhead myself, keep posting. Dick Z
| Richard , thanks I'll try to post some pictures later when I get it set up , I am selling a miller bobcat to make working floor space for this set up now and other that staying single phase power should be least of my problems ..lol Robert |
| Goldhunter_2, You state that you believe that a lathe with a 6 inch swing would be sufficient. WRONG! When you grind a rod journal on a crankshaft then the rod journal is running on center while being supported by a steady-rest. That leaves the balance of the crankshaft swinging in an orbit around the rod journal. In summary, a lawn mower crankshaft rotating on the center line of the rod journal would easily consume a 6 inch swing. If you wish to continue this persuit then I strongly advise you to locate a used Storm Vulcan or Van Norman crankshaft grinding machine. Be advised that you will have to regrind a heck of lot of crankshafts to justify the expense. RFB |
| Richard, subcontracting or sending the cranks of is what I have done in the past but is getting to the point where it would be more beneficial to me personally to set up a small grinder of my own Nothing big like RFB is talking about just to be able to do my own stuff RFB, it would be nice if I was able to just right a check for a big used Storm Vulcan or Van Norman crankshaft grinding machine but like I said there just not in the budget nor practical option unless I wanted to open a shop to pay for it witch I don't nor do I have the working floor space to house a machine that size I may have possible worded my earlier post wrong it would not be the first time my typing did match what I meant ..lol at a 6" swing I mean 6" form the chuck center to the bed of the lathe . I just remeasured a lycoming 540 crank I have laying out here and counting the prop Flange it is under 7" total or form the journal centers to the farthest outer point would be under 5" I believe by what you post says that should be enough clearance now you have raised another question in my mind I'll explain best I can. you said the crank would have to be centered on the journal and I took that as the grinder wold be fixed ......... I have only been around a grinder once years ago (others have just been shipped off lately) so maybe there are different types but the one I saw and what I was thinking of was more like a old style copier (for lack of better wording ) the crank was center on the mains the grinder would pivot in and out with the journals it had what I would call a following arm like a old key or decoy copier that would keep the grinder wheel rotating around the journal as it turned ......... is what I saw a different type of system then a crankshaft grinder or just a older style? is there a "proper" name for this type of set up ? |
#10
| Goldhunter_2, It's become apparent that advice from those wiser than you will not detour you from your thought of using a lathe for a crankshaft grinder. Just for starters, the bearings in the head of your lathe do not have the integrity plus your tailstock is static versus being powered and synchronized with the head. Wakeup, take a break from your wet dream, go to an engine rebuilding shop and request permission to watch while they setup and grind a crankshaft. If that does not enlighten you then you'll just have to learn the hard way. The value of the time you spend trying to convert your lathe to a crankshaft grinder plus all of the crankshafts that you will screwup will make the price of a used crankshaft grinder seem very reasonable. This advice is coming from a person who has many years of experience wih crankshaft reconditioning (Ran grind shop for Swick-Guth, a company that was a Caterpillar certified engine rebuilder (2 cylinder starter engines to D12 engines) prior to Caterpillar doing their own rebuilding) and many more years of lathe experience (Boeing Military Aircraft, CertainTeed plastics tool and die division, Cincinnati Milacron........) In summary, You're peeing in the breeze and looking like a fool with the pee dripping off of your ears. RFB P.S Please post video clips on UTube as you transition through your lathe/crankshaft grinder transformation. |
#11
| RFB, I never questioned you experience just your attitude . I simplify came on the forum asking for helpful information on a smaller version of something I have seen in the past in a commercial shop , Not your hollyer then then thou attitude That it has to be done the way it is in big shops or not at all . I hnestly don't think you have nor intended any help to my question but rather to show what a ******* you can be There are lots of things big shops tell you can't be done and are done all the time may of these engine are good examples of that . It wasn't like I was asking for a new patented invention or something but rather looking for more information on a old or I guess you would consider antique style system set up that I had saw before I had more of a interest in it Oh and as for your pee dripping ears comment mine are dry but you may want to check yours |
| Making a copy attachment/replicator for a metal lathe? | Rich05 | General Metalwork Discussion | 4 | 11-22-2009 11:20 AM |
| Tool post grinder for haas TL series lathe | L.Kiefer | Haas Lathes | 7 | 11-15-2007 04:39 PM |
| how do you machine a crankshaft or cam | skipper | General Metalwork Discussion | 7 | 10-16-2007 09:39 PM |
| Crankshaft Grinder-basic operation | bluejets | I.C. Engines | 13 | 01-18-2007 05:50 AM |
| Crankshaft machine | Rolovrking | General Metal Working Machines | 1 | 07-18-2004 02:51 AM |
