Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 03-18-2005, 01:34 PM
Wild4aces's Avatar
Wild4aces is on a distinguished road
The X-Axles... to move or not to move!
Currently, I am designing my first CNC Router similar to the JGRO plans using a mild steel square tube frame. The first big design issue I face is the X-axles… should the X-axles be stationary or should the X-axles move with the Gantry stationary?
I have both sketched out, but would like some input on the pro’s and con’s of each before meeting into construction.
Wild4Aces
Old 03-18-2005, 02:26 PM
buscht's Avatar
buscht is on a distinguished road
My first design had the table moving in both X and Y. The routers moved up and down in Z. This worked OK, but I didn't like that all the dust and crude would fall down right on the leadscrews and linear rails.
I am working on my next design where the table is stationary and the gantry moves in both X and Y.
It seems to me that moving the table in X is a little easier to build, but it you move the gantry your overall footprint is smaller.
No Z up on move CNCadmin Mach Software (ArtSoft software) 4 03-20-2005 01:08 PM
Speed how fast an axis can move? jlagran he General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2005 11:05 PM
how does mach 2 and similar programs know how far to move ? Apples General CAM Discussion 1 05-11-2004 03:43 AM
Compensating after stopping a move wjbzone TurboCNC 1 05-18-2003 11:45 AM
User coordinate system? HuFlungDung OneCNC 5 04-18-2003 10:26 PM
