| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| Hi Ken The answere is yes but there are a lot of disadvatages! 1. The gearing is all wrong to get a supper smooth finishing cut. The pinion is sized on the normal lathe apron to give rapid movement (traverse) under hand wheel control. The lead screw can drive at slow speed and hence get a smooth finish as the cutting edge overlaps at each sucessive revolution. 2. The turning of the chucked object and the advance of the tool need to be synchronised accurately for screw cutting operations. 3. Yes there will be a lot of backlash but that is secondary to the above two points. 4. This could be made to work with a fine toothed rack and a small pinion combined with an accurate DRO and some cute software manipulation. Hope this helps crystalise your thoughts. |
The biggest issue for cnc operation is the backlash - It'll be difficult to remove unless you can fit a pair of pinions and have a pair of motors (one driving one way one the other).
__________________ Bill |
| Alternative to Ball Screw or Rack-n-Pinion | samualt | Linear and Rotary Motion | 38 | 09-28-2011 11:07 AM |
| Rack & Pinion vs Lead Screw | E-Stop | Linear and Rotary Motion | 51 | 08-19-2009 12:53 AM |
| RACK AND PINION WITH SCREW DRIVE | ballardtile | DIY-CNC Router Table Machines | 2 | 03-11-2009 04:27 PM |
| Rack & Pinion vs Ball screw | jwagner | Linear and Rotary Motion | 1 | 03-25-2006 01:38 PM |
