| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
I have a old heavy duty drill that I want to pull the motor out of and replace it with a stepper motor. The problem I have is that the motor shaft has a gear cut into the one end of it to drive the gear reduction head. I want to make a adapter shaft to go on a stepper and then ride in the drills gear reduction heads bushing. The motor shaft gear has 9 teeth and has a OD of 0.380". How can I find the DP and pressure angle of the gear so I can find a prodcution gear that I can modify to fit my stepper. I found a bunch of gears at sdp-si.com but I could not find any 9 tooth gears that had a OD of around .380" I would appreciate any help in figuring out what this gear is and a possible supplier of them. Thanks Scott |
| Look in the metric gears. If it were english, Pitch=(teeth+2)/OD, which doesn't give a valid pitch in english.
__________________ Mike Visit my projects blog at: http://mikeeverman.com/ http://www.bell-evermannews.com/ http://www.bell-everman.com |
| I was thinking to re-use the motor shaft with the gear hobbed into the end of it but then I have to make a housing about 6-7" long to house the motor armature. I dont want to destroy the motor as I may want to put it back together some time and use is as a drill again. That is why I was trying to figure out what kind of gear this is so I can just put a stub shaft onto my stepper and make a adapter plate to hold it all together. The thought on it being a metric gear I dont think would be correct as this drill is from the 1960's. I dont think they used metric gears back then. I am thinking of pulling the head apart and measuring the mating gear and the motor gear to see if from the 2 I can get the numbers to point more to what it is. The pressure angle, I think, is going to be hard to figure out though. Scott |
| My guess is this is a 28DP gear. 9 tooth 28DP gear would have a 0.3928571 OD. (Textbook size) I find a lot of gears a little smaller than textbook size. Since you are measuring a gear with a odd number of teeth your .380 OD would be a little small, (I am assuming you measured the OD just outside to outside, Not center of gear to the outside of a tooth (radius) and doubled that, so you had one tooth on one jaw and two teeth on the other jaw of your mic(caliper). |
| I did just use a caliper and I bet I did get between 2 teeth on one side. I will have to measure again and rotate it a little to see if it gets any bigger. I will do some looking for a 9 tooth 28DP gear like you suggest. Do you have any good places to find small gears like this? Many thanks! Scott |
| I went and remeasured the gear teeth with a caliper. It measured .348" at a minimum and .353" as I rolled the gear. The smaller dia was with 3 points of contact. 1 tooth on 1 side and 2 on the other. What would that calculate out to for a Dp with 9 teeth? What formula do you use? Thanks Scott |
| How to determine taper? | em123 | CNC Tooling | 4 | 01-14-2008 07:50 AM |
| Determine motor RPM... | WilliamD | Servo Motors and Drives | 2 | 12-09-2007 08:53 PM |
| Is it possible to determine which phase is which? | phantomcow2 | Stepper Motors and Drives | 1 | 02-25-2006 06:53 AM |
| Basic Bevel Gear - Milling a valley for gear teeth | ngr1 | General CAM Discussion | 9 | 04-17-2004 04:58 PM |
| How Can You Determine.... | jonbanquer | Fadal | 12 | 01-08-2004 07:16 PM |
