| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Can anyone tell me the formula for X and Z co-ordinates when you rotate the B-Axis around the centre of a horizontal machining centre and the you have a part or fixture which is sitting at z200. Assume that the part has been loaded at X 0, Y 0 and the hole is on Y0. eg. Say I want to drill a hole at 45° on a diameter. My component is Z200.0 from the centre of the table(centre of rotation). I rotate the B axis 45° around the centre of the table . What would my x and z figures be. |
| I'm guessing you have a cylindrical part clamped to a tombstone, and the cylinder is oriented vertically, parallel to the Y-axis? Also, you want X-zero to be the center of the cylinder? Z-zero = cos(B) * (200.0 - R) + R X-zero = sin(B) * (200.0 - R) B = B-axis rotation in degrees R = Radius of the workpiece Different formulas if you're cutting flat workpieces. -Sol Glacern Machine Tools |
| Hello fitzpatrick, you can download and use CNCOffsetCalculator for calculation of the offsets on horizontal machining centres - it gives you the X,Y,Z coordinates (if you know exactly the position of the workpiece) or it generates a CNC code (G10 code or system var) and the machine will calculate the offsets when it runs. You can download the program from cncplusplus.com Regards, Zdenek |
| Need Help!- Need to purchase 3AXIS Machining Centre | camgp | General Metalwork Discussion | 4 | 05-17-2009 08:10 AM |
| 5 Axis Machining and 6 Axes Turning Centre available | syamin | Product Announcements & Manufacturer News | 0 | 02-15-2009 07:25 PM |
| Problem on CNC machining centre (VMC) | sunilsawant123 | CNC Machining Centers | 2 | 10-10-2007 11:53 PM |
| Low cost machining centre retrofit | motordude | General Metal Working Machines | 2 | 01-07-2005 02:32 AM |
| Anyone got any vids/pics of a cnc machining centre with....... | Darc | General Metal Working Machines | 3 | 11-28-2004 04:06 AM |
