| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Below are some pics of my home made 4th axis for my Bridgeport. I'm using a 570 oz.in Stepper with 72VDC. I used a lathe head for it so it's interchangeable with my lathe. It's just using a belt reduction for power transmission. The problem I'm having is that with the leverage the chuck provides it moves when I'm cutting something on it. I can move it by hand while it's not moving, it takes a little force to move it, but I can move it no problem. I have it set at full power on my driver when it's at a standstill. Now I understand that there is no real transmission on it and no means of keeping it from antirotation as a worm gear drive would provide, but would this setup in your opinion be that weak? If it works and I can engrave lightly then it's not a wiring problem I'd guess? Any suggestions on how to easily modify this setup without having to purchase and build a worm gear setup? |
Your holding torque is the stepper torque multiplied by your pulley ration. Make sure the driver you are using does not have the current reduction feature enable, other wise the holding torque will be reduced considerably. Set the current limit to the highest setting, consistent with not exceeding the specs of the motor, driver or power supply. You won't do any better than that without more reduction, or a holding brake. Professional units use a drag brake that is strong enough to take all the cutting loads, and an encoder and a servo to move it with brute force. That gets rid of the backlash. There is none.
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
Not exactly. What I am saying is you need some minimum value of holding torque, which is dictated by the cutter loads in your case. As you may have noticed while doing milling, you must clamp work pieces very firmly to resist the force the cutter/drill etc exerts on the job. It is no different holding something in the chuck. Same rules apply. If torque needed to be resisted is 10 times what the stepper motor can supply, you need at least a 10:1 reduction to just break (no pun intended) even. For similar reasons, your machine is big stiff and strong, to resist cutter loads. Once the job/cutter deflects more than the chip load, then you get chatter, but that's another story.
No. It will only take light cutting loads. What current is the driver set to? What driver you using? Post some specs.
| I'm using a Keling 8078 Driver, http://www.kelinginc.net/KL-8078.pdf and the current is set to 72VDC and 2.1A...I think there's my problem I thought I had set it to the correct current but I just went and check while writing this post and it's not right. According to the stepper documents the current is 5 amps. Now on my driver it says Peak Current and RMS Current, the stepper doc only says 5A, does that mean peak or RMS? Here is the doc for the stepper http://www.kelinginc.net/KL23H2100-50-4B.pdf. Thanks. |
| I'm going to guess that even with the correct current, you'll still need more belt reduction, at least a 2 stage to get you close to 10:1.
Set the driver to 4.9A. That will be within the ratings of the motor. If you wire up the enable signal, you will be able to 'disengage' the drive to rotate the chuck by hand. It should work OK for light engraving. There does not seem to be a way of defeating the idle current reduction, so as a workaround, you could command it to step backwards and forwards 1 microstep while stationary. This will increase the holding torque considerably while only moving an almost imperceptible amount. Contact keiling to see if the feature can be disabled selectively.
#10
| I changed the amps to 4.9 and I can still move it but it's definately stronger. It might work this way. Neil, why would I want to rotate it by hand? "There does not seem to be a way of defeating the idle current reduction" Do you mean the holding torque? Because there is a DIP switch on the driver to set it to full or half? If this is not what you mean can you expain further including the part of moving back and forth a bit? |
#11
Set that switch to FULL and try it. Whichever position gives the higher holding torque, use that one. Just turn against it with your hand. You should feel the difference. That was not in the document file I read. Rotating by hand during setting up a job, getting the chuck to a convenient position to use the chuck key. In your application there may be no need for this, but the driver has the feature. Unplugging a stepper while the power is on can kill the driver. That's one reason the enable signal is useful. If you need to disconnect the drive, you can disable it, then unplug it without frying the driver.
#12
| OK gottcha, always wondered what that feature was for. Thanks. So I do feel a difference by changing the holding torque, but does your way of moving the axis a microstep back and forth have any advantages now that I have set the holding torque to full? |
| x axis slipping | FUN4ME | Fadal | 2 | 01-08-2008 03:20 PM |
| Y Axis Slipping ?? | twocik | Benchtop Machines | 18 | 12-11-2007 06:11 PM |
| stepper motor internals and drive slipping help | rally.sport | Stepper Motors and Drives | 1 | 01-03-2007 04:30 PM |
| EZTRAK Y axis loosing position, "slipping" | melamark | Bridgeport and Hardinge Mills | 7 | 12-18-2005 02:23 PM |
| Boss z-axis belt slipping | jderou | Bridgeport and Hardinge Mills | 13 | 06-01-2005 02:08 PM |
