What you are quoting is actually a 20 turn per inch screw! If it is then changing the steps per to 8000 should show an improvement!The acme screw is a 0.5"-10 screw![]()
Hello all,
I am just about to get my cnc router up and running for the first time. It has been a long process of building it. I have a questions about my feed speed, and I will start with giving you some general specs on my set up.
I have a 200 step per revolution motor with 150 oz inches. I directly couple them to my precision acme thread using a spider coupler (LoveJoy). The acme screw is a 0.5"-10 screw (10 turns per inch). And I am driving my motors with a home built stepper motor controller, which is using half-stepping. I connect everything to Mach3 to run it.
that being said I believe that I should have 4000 steps per inch of travel. When I test everything out it runs fine at around 10 inches per minute. But this seems very slow compared to what I am reading about cutting speed.
Am I doing something wrong? Have I picked parts which were poor choices for a first time cnc router? any advice is appreciated.
Josh
Kawazuki,
Thanks for the response. However I do not see how it is a 20 turn per inch screw. Here is a link to the mcmaster page for the screw.
http://www.mcmaster.com/#99030a005/=3n0ynb
0.5"-10 is a half inch diameter screw with 10 turns per inch.
Could you explain further?
Also, I have increased the speed in Mach3 and I lose torque. This means I can not just turn up the speed much further because I will not have enough torque to move the screw. If I understand Mach3 correctly, increasing the number of steps per inch, would be about the same as increasing the speed. both result in a higher frequency of steps per second, however if you don't have the steps per inch set correctly you would not be accurate.
Josh
Are you using microstepping drives? Then you need to multiply your step per inch by the number of microsteps.
4000 steps/inch is correct. The problem is the motor is too small, and 10 turns/inch is really just to many. The motor has to spin too fast, and steppers lose torque the faster they spin.
I don't know how big the machine is, but for more speed, you'll need bigger motors and higher pitch screws, like 1/2-8 2 start, or even 1/2-10 5 start.
Your motor speed is 1.67 revs per second at 10 IPM using a 10 TPI screw. That is very slow. A reasonable speed would be 100+ IPM with that TPI screw. You must be using a very low power supply voltage and/or a high inductance motor (low rated phase current). My guess is 12VDC supply and a 1A per phase motor to get such results.
Mariss
Thanks everyone for the input. I will be investing in different lead screw and more powerful motors as one of my first upgrades. It is a lot easier to upgrade once you get the dang thing running for the first time.
Josh
Your homebuilt drives may also be a factor, and may not get the full advantage out of larger motors. Drives, motors, power supply and screws all need to work together as a system for best performance.
