Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-06-2009, 04:31 PM
15mgtar is on a distinguished road
newbie don't know his load rating pls help
Guys pls help what is a basic dynamic load rating: 32.75 C(kN) and basic static load rating: 76 Co(kN). I don't have a clue to what and how much it weight it can hold. I only know dynamic means while moving and static is while stand still. This I got from Hiwin linear guideway.
Old 09-06-2009, 04:44 PM
Mike Everman is on a distinguished road
The C and Co are directions of load force, which you'd see in their illustration. C is usually straight down if the rail is down on a table and the block on top.
kN: kilo=1000 N=newton force=.224 lb
Mike Visit my projects blog at: http://mikeeverman.com/
http://www.bell-evermannews.com/ http://www.bell-everman.com
Old 09-06-2009, 09:24 PM
Thank you Mike!
so the calculation will be like this: (1000x.224)32.75=7336 lbs and as for the static is (1000x0.224)76= 17024 lbs?
about Co is for static load rating right? or it's C for static load rating? because in the manual it says basic static load rating : 76 Co(kN).
So if My calculation is correct I can put a max of 17024 lbs of material on top of one of the block?
Old 09-07-2009, 10:27 AM
Look in any linear bearing catalog or site. There is some simple algebra that you should go through to determine the equivalent loading that your setup puts on the bearings. Generally, as you can see, the bearings take far far more than we'd usually apply.
Vendor Rating pete00 Laser Engraving & Cutting Machines 0 07-30-2009 07:17 AM
Newbie Question: hand-cranked Z-Axis for 200lb load patriqq Linear and Rotary Motion 7 11-18-2008 10:00 PM
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 07:10 PM
Another A+ rating. cephjedi Automation Technology Products 1 04-27-2007 09:39 AM
KVA rating help... delangecycles General Electronics Discussion 4 04-18-2006 09:30 AM
