Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 08-20-2009, 05:39 PM
satanicoo is on a distinguished road
Gearbox with a 30:1 reduction for my stepper
Hello guys,
First i really don't know if this is the correct forum, but this one sounds more fitted to my question, compared to linear/rotary motion.
The problem is quite simple, i need a 30:1 somewhat gear for my small step motor, it has a 3mm shaft.
For now, i would like a cheap one for tests, and on the future a good anti-backslash version for my small cnc creation.
Do you know any store that sells cheap gears/gearboxes for small motors?
I searched on ebay:
http://cgi.ebay.co.uk/12V-DC-300-RPM...d=p3911.c0.m14
And found several of those, i would just have to remove the motor.
The seller doesn't know what is the motor shaft diameter or the gear ratio of it, and doesn't comply in opening one to confirm them.
Do you guys have any idea that could help?
Old 08-20-2009, 10:35 PM
Matt Adams is on a distinguished road
Post
I can ensure you that the ratio is simply too high to use with steppers and get any sort of reasonable performance from steppers unless you're planning on getting something less than 50 RPM out of of the motor and less than 2 RPM out of the gearbox.
The reason I say this is relatively straightforward - the loss in torque at speeds greater than 300 RPM begins to really tapper off. Anything above single digit ratios with stepper motors typically means you'll have more torque at a lower ratio because of the fall off.
What sort of torque and speed outputs are looking for? Many of us on the forum can help.
Matt
Name:	stepper performance typical.jpg‎
Matt Adams - Motion Control Application Engineer
IMAC Motion Control - Elgin, IL
Old 08-21-2009, 09:26 AM
Hey there,
Searched a bit, and:
PLANETARY GEARBOX
this link gave a good help, i just have to keep digging on ebay.
The use i would give it is to use as a very slow rotating table. Hard to give more details, it's a "special" project.
PLANETARY GEARBOX BOBINETTE Stepper Motors and Drives 3 07-12-2009 05:16 PM
Need Help!- VF-6 50 Gearbox BJSwart Haas Mills 0 03-10-2009 10:01 AM
Need Help!- Gearbox vibration rshields21 Haas Mills 1 01-20-2009 08:36 PM
Direct or geared reduction to threaded drive ? (stepper) andy_ck87028 Linear and Rotary Motion 4 03-13-2006 08:42 PM
gearbox reduction unit senor J. DIY-CNC Router Table Machines 3 12-13-2004 01:46 PM
