Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 08-07-2009, 09:42 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Cool Codes used in CNC
hI,
I have read about manytypes of CNC like Plasma, grinding, wirecut, hmc.
I would like to ask all of you that what are the Codes used in this all machines.
I am very much familiar with G & M codes for turning & machining centre.
I was curious to know if any other codes or coding language is used in other machines...
I refer to general codes like G1, G2, M05 & so on.
Ash
Old 08-07-2009, 09:51 AM
Al_The_Man's Avatar
There are unique G codes for EDM, Plasma, Punch etc they are to long to list here, I suggest you do a Google and see what comes up.
I have them in book form but none in pdf.
M codes to some extent are standard for each machine also, but can vary due to being written by the MTB, so these can have individual purpose unique to a machine.
Old 08-08-2009, 03:04 AM
Ashish B's Avatar
Cool
Can you favour me up with those codes...I refer to uncommon codes or can u let me give any keyword for google it down.
Ash
Old 08-08-2009, 07:30 AM
Superman's Avatar
Superman is on a distinguished road
I don't think you understand what Al_The_Man said about each machine maker having thier own set of codes, the task of finding out what each code means for each type of machine ( mill, lathe, EDM, plasma, hacksaw etc ) and also from all manufacturers is an enormous job.
You ask for a favour, don't be surprised if you don't get a reply.
an example
G56 -- on an Okuma mill is tool length offset, on a lathe not used, on a FANUC ---who know's -- I don't care--- I run an Okuma mill
G43 -- on a FANUC mill is tool length offset, on a lathe ??, on an Okuma is 3D cutter comp--- I don't care about FANUC -- I run an Okuma mill
An old adage--- a man that knows a little about everything is dangerous.
so my advice, pick a machine, learn it, use it, and then you may one day be classed as a good operator/programmer
Old 08-09-2009, 06:32 AM
Ashish B's Avatar
Wink
an example
yA I got your point..
I am quite aware about the G Codes ( plenty.from G00 to the end ) & also have a fanuc & mitsu manual for refering those...
The cnc hub is mainly distrubuted in 2 groups - Machining centre & Turning centre...Than comes the Boring, grinding & so on..
I been a CAM programmer since 4 years have a good knowledge & control over the cnc lanuguage..I was just concerned about any specfic or codes (which we never come across in CNC Lathe & mACHINING CENTRE )..
Thanks buddy fr your valuable info..:-)
G68 and G69 codes kot137 G-Code Programing 5 06-24-2010 12:51 AM
Need Help in M codes chetan CNC Swiss Screw Machines 2 03-09-2009 08:39 AM
M-codes and G-codes 4 Matsuura ES-1000V maximusek G-Code Programing 2 11-27-2007 07:41 AM
g codes AJFab G-Code Programing 1 05-19-2006 09:16 PM
g-codes pimp215 General Metalwork Discussion 11 03-07-2005 02:43 PM
