Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 08-05-2009, 11:13 AM
fsa fsa is offline
fsa is on a distinguished road
Red face heat treatment issue plz help
hello engineers i am facing big problem about heat treatment of a very deligate tool steel part(dimensions is O.D170mm not exact round but like cam profile and I.D 150mm not exact round but like cam and thk is 1.5mm which is veri from different protions of ring material is D-2 and req hrc is 58~60. i have not enough knowledge about heattreatment.i need advise about heattreatment process wat is the best process for this type of thin section parts if some one see the actual part i can send him jpeg for better understanding.
thanks
fsa
Old 08-05-2009, 12:43 PM
fsa, Is the piece hardened before or after final machining/grinding? I had an experience with D2 at 58-62 Rc. This was finish ground after heat treating.
These pieces were heatreated (hardened) in an electric inert atmosphere (nitrogen gas) oven and then subjected to a liquid nitrogen bath while in the same oven.
Pieces were stable after this treatment with no distortion after finish grinding.
Your 1.5 mm thin areas can present a cracking proble unless the finshing operations can remove heavier material amounts after hardening. (contour grinding after hardening?)
Dick Z
DZASTR
Old 08-07-2009, 03:09 PM
juergenwt is on a distinguished road
Fsa - I am with Richard. I had many punches and dies made out of D-2.
D-2 is very stable and has next to zero distortion in heat treating. A good heat treater should not have any problems at all. You can keep your range to within +/- 1 Rc.
I always attached a special note: "No distortion" to make sure my parts were handled with the proper care. Like Richard said, 1.5mm is very fragile at 62 Rc.
Old 08-08-2009, 05:26 AM
fsa fsa is offline
plz check image of my problem
engineers plz check the part and i thing after heat trteatment grinding operation is not the easy task and idont have any machine to do this.still in trouble plzzz support me
asif fsa
Old 08-08-2009, 11:08 AM
fsa, what machine is used to produce these contoured parts? What spindle speed is available/possible? It may be possible to grind the contours with the same machine.
If the present machine's spindle speed is not fast enough, a grinding attachment could be used by adding to the existing spindle.
add: www.vulcancut.com/vulcanaire.html
Dick Z
DZASTR
Old 08-14-2009, 07:33 PM
fsa- What is the tolerance for all the dim's?
Since it is a metric print they could be using "General tolerances as per DIN/ISO2768". Let me know.
What is the function of the part?
The reason I am asking is that you have a lot of people designing things on CAD and specifying a material without regards to the function of the part.
Using D-2 for such a fragile part is not a good idea. You could be saving someone from spending a lot of money for something not needed and will actually make a bad part.
Bin there!!!
Old 08-15-2009, 05:19 AM
kawazuki is on a distinguished road
Dick Z
Interesting tool but come on .....300 series - 3,000,000rpm!
Old 08-15-2009, 11:55 AM
Sharp eyeball there!!!!!!!!! I didn't see that, must be a proof reader error or lack of proof reading. LOL
Dick Z
DZASTR
Heat treatment of stainless steel. zoeper General Metalwork Discussion 5 12-18-2008 09:19 AM
Heat treatment for lathe spindle shaft mackeym General Metal Working Machines 10 10-15-2007 05:05 PM
to heat or not to heat - that is the question? stirling Stepper Motors and Drives 15 09-04-2007 04:44 AM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 04:19 PM
Heat Treatment georgebarr General Metalwork Discussion 7 04-18-2004 02:08 PM
