Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 08-03-2009, 01:28 PM
Apresto is on a distinguished road
Question 20 ton die cast sprayer
Hi all,
I am a die cast engineer from S.Africa, I am looking to build a new sprayer for our machine. Its a reciprocating head and we use mineral base die spray, it is very old and messy but this is the least of our problems I also need to control the spray volumes, there are 2 settings at the moment- TOO much and TOO little. We are using a FESTO controller to control the length of stroke and spraying time. It is pneumatically controled and the die spray and air is pre mixed in a small pressure vessel attached to the back of the machine. It can be set up vertically or horizontally. If need be I can attach some photos of the sprayer?
I would like some tips on the pneumatics of the sprayer and a few sprayer head designs?
Apresto
Cast or Machine Kipper Casting Metals 59 02-06-2009 03:25 AM
$ JOB $: Looking for someone to Cast Parts. travis_towle Employment Opportunity 0 07-25-2007 07:08 PM
mold release sprayer smarbaga Mechanical Calculations/Engineering Design 5 02-01-2006 08:46 PM
