| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Hello Are there absolute measurement devices? Device that can measure absolute height of a point? for example lets say I need to measure two point when each point is on different location, but what I need to know is the differential between the two points although I have different ground height for each point, and the ground height is unknown (in comparison to sea level height) p.s. (for moderator) I asked the same Q in a different format before, hope it's not a problem, if so, let me know |
| What is the distance separating the points and the difference in height? For distances less than 100ft and heights that differ by less than 10ft probably a plastic tube is the simplest. If you have lots and lots of money you can get GPS based instruments that give heights and distances in the millimetre range; this are used to detect ground motion around volcanoes and to monitor tectonic movement. Or you can pick up some surveying equipment and triangulate it.
Triangulation sounds very interesting, maybe it's possible to triangulate the right equipment to get a real good accuracy, I will search if someone has done it before |
| I recently saw a gadget that will track an eyeball sized retroreflector and give its position within three thousandths of an inch in a 40 foot cube. (I believe I got those numbers right.) Do you have a few hundred thousand spare dollars in your budget? What precision are you looking for? Ken
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
![]() I have only 2K$ in the budget for that specific assignment, but I don't need to buy the device only to use it. Where did you read about it? It sounds interesting even if a bit unpractical |
| A thought just entered my mind. Fixtures for assembling small aircraft wings are optically aligned and calibrated to locate the 'hard points'; you need to find someone involved in this type of thing.
| I went to a presentation on this stuff a couple years ago. Seemed pretty darn cool. http://us.metris.com/large_volume_me...y/laser_radar/ 102 micron accuracy at 10m distance. But as stated previously, LOTS more than $2k. I think the tube method would work, you just need to devise a clever way to measure the water height at each end of the tube. Something like a graduated cylinder which connects to the tube. Matt |
#10
Thanks for all you ideas; it was very kind of you to help Yovav |
| external devices connected to a CNC machine | sinha_nsit | Fanuc | 17 | 03-07-2009 04:04 AM |
| Need Help!- I need a measurement from a Sherline CNC kit... | vlmarshall | Benchtop Machines | 2 | 01-28-2009 11:10 PM |
| Wow, these measuring devices are WAY cheap.. can I trust them? | squale | General Metalwork Discussion | 11 | 11-22-2007 06:12 AM |
| Info on Eastern Air Devices ??stepper?? | mpmarino | Stepper Motors and Drives | 5 | 11-30-2006 11:59 AM |
| Looking for info on K2 Devices and EZ router | Trexler Signs | CNCzone Club House | 0 | 08-23-2006 11:08 AM |
