| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| Rotary axis machine I am starting on my first machine, which will have a, y, and z axes. It is to be used to engrave/cut around cylinders .5 to 1" dia, and up to 8" long. Materials plastics, brass, maybe wood. Depth of cut .125" max. I have a 4" rotary table that I am planning to put a stepper on. I am not sure if I want to build as a lathe with controllable spindle or as a gantry machine with the table and rotary table stationary. My first question, is this the proper forum to post my questions? Thank you for your help. |
| I added a 4th axis rotary to my machine and mostly use the xza setup. Don't use Y very often. Unless doing continous engraving around a cylinder. Check out my website to see what is capable with a 4th axis table. www.whiterivermfg.com Donny |
| Whiteriver This is the type of machine I have but am trying to decide what software to use. What do you use? Thanks Rich |
| I use VisualMill and am trying to learn Deskproto for the 4th axis stuff. CNCtoolkit is a good free option for use with Gmax or 3D studio Max or Autodesk VIZ i believe. Rumor Meshcam will support 4th axis soon. That could be a very good priced option for alot of DIyers. Donny |
| try master5 it has x y z a you can set A for linear or angular http://www.artofcnc.ca/product.html is limited vertion but i haven't found the limit yet. |
| CNC Glossary | CNCadmin | CNCzone Club House | 17 | 03-09-2008 04:08 PM |
| My First CNC Machine, Mr. Chips | Mr.Chips | DIY-CNC Router Table Machines | 81 | 02-10-2007 10:04 AM |
| Calculating "steps per unit" for rotary axis? | Beezer | Mach Software (ArtSoft software) | 2 | 11-28-2004 04:31 PM |
| What Cam software for a 9 axis machine? | nervis1 | General CAM Discussion | 13 | 11-26-2004 11:25 PM |
| 2 axis linear machine control ? | vostryc | General CNC (Mill and Lathe) Control Software (NC) | 2 | 09-05-2004 08:30 PM |
