| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| I am looking for a source for a high speed rotary coupling that will handle 35,000 rpm. thanks camme |
| I'd like to find a solution for attaching coolant to a high speed spindle as well... There are a lot of things to be conserned about though. Pressure, RPM, syntrifcal force... I wonder at what point coolant that is pumped through a rotating spindle would just spin off laterally because of syntrifical force? If it did, it would not reach to cut zone... Interesting,
__________________ Scott_bob |
| Dab, Thanks for the link. I look at these and they won't handle 35,000 rpm or 2000 psi coolant. Also the taper on this Okuma is a HSK 63F. It had a 25000 rpm rotary that wouldn't handle the high rpm. Again thanks, camme |
| Scott bob, The coolant is expelled thru an ER16 collet or the tool tip and at 2000 psi has no problem putting 8 gpm in the cut zone. Thanks for your reply, camme |
| I beilieve "Barco" makes rotary couplings that can handle the speed and pressure. They are costly, as they utilize two polished ceramic surfaces to make the seal.
__________________ menomana |
| http://www.barcoseals.com/coolant.htm Actually they are only good to 1500 psi, 20,000 rpm.accordiing to the web site.
| What is high speed machining | Klox | Hard and High Speed Machining | 111 | 01-26-2011 01:21 PM |
| High Speed Hard Milling | MachineSMM | Hard and High Speed Machining | 24 | 03-27-2006 07:31 PM |
| What is high speed machining | johnm | Hard and High Speed Machining | 22 | 12-29-2004 05:41 AM |
| high speed rotary table? | jleiwig | Benchtop Machines | 1 | 11-17-2004 10:39 PM |
| High Speed Spreadsheet | MachineSMM | Hard and High Speed Machining | 15 | 07-20-2004 05:41 PM |
