Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 07-15-2009, 12:25 PM
Rockwall is on a distinguished road
Wall thickness for threaded tubing
Hi, I'm not an engineer so I'm sorry if this seems like a dumb question, but I'm designing a part that is a piece of 1.5" titanium tubing that is threaded on the inside so that a cap can be screwed on, similar to the cap on a Mag Lite.
Can a tube a wall thickness of .039" be used for that?
What should the thread pitch be?
Old 07-19-2009, 02:09 PM
Cartierusm is on a distinguished road
It all depends on the thread pitch, but as you asked what pitch you should use you're on the right track. 16 TPI for example would not work as the depth of the thread is .0338" and that wouldn't leave too much meat on the wall. I would go with 32 TPI whose thread depth is .0169". Are you going to thread this with a tap or use a lathe? Finding a tap like that would probably be very expensive. If doing this with a lathe you better get or make the male part first as it's probably smaller and cheaper to make than the tube part as you'll need to continually test as your cutting to make it fits correctly before taking the part off the lathe.
T304 Stainless .065 wall tubing l u k e Welding, Brazing, Soldering, Sealing 7 06-05-2009 04:46 PM
What is the best way to cut thin wall brass tubing? lerman General Metalwork Discussion 9 03-27-2009 03:58 PM
Problem- milling thin wall brass tubing jackie_burton@m General Material Machining Solutions 11 09-29-2008 04:46 PM
Steel rectangular/square tubing wall thickness pstockley General Metalwork Discussion 0 01-27-2006 02:56 PM
