Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 02-16-2005, 04:03 PM
Jay C is on a distinguished road
Thumbs up Alternate Lead Screw Mounting Idea
I couldn't think of a better description for my solution I came up with on my CNC lathe project. I have a Taig Micro II lathe that I am adding a lead screw to followed by CNC control. This will be my easy win to guage my intrest in this part of my expanding hobbies.
Since the lathe is so small (but big enough for what I use it for) I couldn't think of a safe way to turn down the ends of the screw for the bearing blocks. My solution, turn then tap some adapters of aluminum that screw onto the ends of the screw and are turned to size for the bearings. In my case I am using 3/8 - 16 all thread and some bearing assemblies that have a 3x.5mm boss screw so my adapters join two male screws.
It may not be original, but I've not seen anyone use it ... are there issues I need to be aware of? I'm using a 4-jaw chuck and tailstock drilling and tapping.
Thanks,
Jay
Old 02-16-2005, 04:17 PM
ViperTX is on a distinguished road
You'll probably need to pin or set screw so they don't untighten when reversed.
Old 02-16-2005, 04:31 PM
OK, but if they are wedged in between two bearing blocks (like I've seen on most of the router tables) how could they unscrew. And if tere were a possibility, some loctight should be enough wouldn't you think?
Old 02-20-2005, 01:18 PM
yukonho is on a distinguished road
Hi Jay.
I would think that a simple locknut would do the job. I cant quite picture what you mean by wedged between bearing blocks. Medium loctite should do just fine too.
How about some pictures of your set-up?
colin
Old 02-20-2005, 02:32 PM
Originally Posted by yukonho
Hi Jay.
colin
Hey Colin [url-"http://www.cnczone.com/gallery/showgallery.php/cat/500/ppuser/7358"]my gallery[/url]. Hope that makes it more clear.
BTW, just tested it with a drill ... the leadscrew works Now I need to figure out a way to extend from the bearings for a handcrank on one end, and a stepper on the other. Let's see how well loctite will hold a 4-40 screw under those torques If not, I have some epoxy, probond, and JB Weld to try too
Jay
Jay
Lead screw whip spalm DIY-CNC Router Table Machines 3 05-24-2005 03:04 PM
cnc lead screw mounting hpghost DIY-CNC Router Table Machines 2 04-11-2005 02:04 PM
One lead screw off-centered..Will it work? bgolash DIY-CNC Router Table Machines 14 04-02-2005 09:57 AM
How to machine a 56 Rockwell lead screw bgolash General Metalwork Discussion 6 12-05-2004 04:25 AM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 09:49 AM
