Results 1 to 2 of 2
Thread: Beam deflection using stainless tubing
    Dec 2004
    Hi Guys
    I need help again!
    I've constructed my frame from mild steel and wish to construct the side rails and gantry rails from hollow tube probably stainless.
    Side rail and gantry assembly will be 3 skate bearings per corner being 12 bearings for each assembly and therefore 24 in all.
    My problem is this. If I use two parallel hollow tubes 300 mm apart and with a span of 1.5 metres, I think I will get too much downward deflection when the router assembly is in the middle. Let's assume the router assembly will weigh 5kg and the tubing is 25.4mm diameter with sidewalls of 1.6mm.
    I have used Beamboy but I am not confident enough that I am setting it up / interpreting results as I should be.
    Hopefully, I have provided enough info.
    Thanks guys
    Andy
    Dec 2004
    Slept on the problem and checked the zone this morning. Found a very recent thread that tackles the problem of support for linear guides!
    Thanks Wile_e
  1. Steel square tubing for frame
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 08-20-2005, 09:44 AM
  2. cant find seamless stainless tubing!!!
    By imwllc in forum CNCzone Club House
    Last Post: 06-01-2005, 11:27 PM
  3. 304 stainless steel slide rods
    By bertvk in forum DIY CNC Router Table Machines
    Last Post: 09-25-2004, 05:35 PM
  4. Formula for deflection of beam
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 09-14-2004, 08:14 PM
  5. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 11:08 AM
