Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 06-05-2009, 11:31 AM
John Welden is on a distinguished road
Stainless spring
Is there a type of stainless that is:
Machinable
Has decent spring characteristics
Doesn't need heat treat after machining
I need to make a stainless collet
Thanks,
John
Old 06-09-2009, 12:29 PM
andypugh is on a distinguished road
"Spring" is more about design than material. Traditional spring materials are defined by having a high ratio of yield strength to tensile limit, but that just makes them more efficient as springs.
To further complicate matters, "machinable" is a rather woolly concept, and the existence of CBN (Cubic Boron Nitride) and diamond tipped tooling has stretched that boundary in much the same way as Carbide did, and High Speed Steel before that.
Have a look around www.matweb.com Perhaps 440C would do what you need.
Spring Winding DIY ? How to MHINK Bending, Forging,Extrusion... 4 02-11-2008 07:34 AM
Gas Spring Specs Chrisjh Syil Products 4 02-09-2008 11:03 AM
HL1 Counterbalance Spring Broke Geof Haas Lathes 2 07-26-2007 01:37 PM
Gas Spring Counterbalance (Swede???) bill south Mechanical Calculations/Engineering Design 3 07-06-2006 05:26 PM
I need a u-nut / spring nut / j nut ljoe1969 CNCzone Club House 1 02-06-2006 04:12 PM
