Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 02-05-2005, 02:16 PM
dsadams is on a distinguished road
Cool CNC Faceting Machine
After reading here on CNC Zone I had an idea for combining my hobby of faceting (gem stone cutting/polishing) and CNC. This could be a very difficult machine to design and program, or not. I am wondering if this has been done before?
The way that a faceting machine works is different from a mill or a lalthe, as the stone is adhered to a dop stick and mounted into the index head which can be rotated and the angle of cut changed, the cutters are a 6" or 8" diameter laps of varying grits of diamond. Then after one end is cut the stone is transfered to another dop stick and the second end is cut and polished.
I was thinking that this might be a neat litttle machine because the range of motion would be very small (small steppers or servos) and the feed rates would be small as well.
I am open to ideas and suggestions for a good design, I would rather avoid mistakes if I can.
Dave
Old 02-06-2005, 01:57 AM
ViperTX is on a distinguished road
Well there are some computerized faceting machines...I've seen pics of some used for faceting diamonds....forget dop sticks...you'll need something more rigid and accurate. I'll see if I can dig up any additional information.
Old 02-06-2005, 11:55 AM
Thanks ViperTX,
The dop sticks are aluminum rods about 5" long and 5/16" dia. using 5 minute epoxy to adhere the stone. These are adequate for the stones that this machine will be cutting, everything except for diamonds because I would have to start over with a different machine and then try to find and purchase rough facet grade diamonds.
I have a Raytech Shaw machine that I have had since 1985, and it has only cut 200 stones, mostly sapphires and garnets, a few turmolines and some amethysts (quartz). Most of the cutting and polishing is done at low speeds 200 rpm and less, for example, Sapphires take a nice polish at around 5 rpm on a ceramic lap with 100,000 grit diamond.
So this will be a big modification of an existing machine.
I would really like to see those cnc faceting machines, that would make my designing so much easier.
Dave
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 10:04 AM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 03:43 PM
My CNC Machine and Questions Davedbq General Electronics Discussion 2 01-22-2005 10:14 AM
Interested in NY/NJ CNC machine demo... jasonsp6 General Metal Working Machines 3 07-23-2004 01:47 AM
World's Cheapest CNC machine @ $100?? SuperCharg DIY-CNC Router Table Machines 2 09-15-2003 08:39 AM
