Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 02-05-2005, 10:05 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
How do I calculate this?
I need to know how much torque is produced for a 45.6 in/oz servo using a 20:1 gear reduction.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 02-05-2005, 10:20 AM
fyffe555 is on a distinguished road
Simple answer is it's 45.6 x 20. More force over a shorter distance is the same as less force over a longer distance.
A more accurate answer is that the gearbox has losses so the calculation is 45.6x20x(efficiency of the gearbox) where Efficiency is, say 50% use 0.5.
Old 02-05-2005, 10:24 AM
Bubba's Avatar
Bubba is on a distinguished road
Paul,
The output of the gear reduction should be:
45.6 * 20 = 912 In oz
or 912 / 12 = 72 ft oz
or 72 / 16 = 4.75 ft lb
Hope this helps
PS: I think your original units should be in oz of torque NOT in/oz???
Art
3 Flute High Helix Endmill Problem Joe_CNC General Metalwork Discussion 7 07-19-2005 08:07 PM
Calculate resistor value for g210 ??????? Biggermens Gecko Drives 0 04-25-2005 03:09 PM
4th axis on the mini JFettig Benchtop Machines 16 01-28-2005 06:38 PM
How do I calculate the strength of a motor? bb99 DIY-CNC Router Table Machines 7 12-04-2003 06:32 PM
