Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-26-2009, 12:24 PM
Spiral_72 is on a distinguished road
Read if looking for V-Groove rollers
There are some inexpensive v-groove rollers on Ebay. The seller implies they are suitable for building a CNC with.
I don't have a problem with the seller. He shipped fast with a great transaction, but the rollers were terrible. I have never seen a ball bearing this bad. What's more, it's an integrated bearing - not replaceable...... so it doesn't appear I can install a higher quality bearing either.
I want to link to the rollers for you, but I don't wish to discredit the seller. I will say, the image in the description shows two v-groove rollers on a magenta background...... Buy from the seller, sure, but don't buy these rollers for a CNC.
Hope this helps
Old 05-26-2009, 12:29 PM
Kipper's Avatar
Kipper is on a distinguished road
These?
Keith
Old 05-26-2009, 03:26 PM
Unhappy
That be the one.
Now I have ten. I dunno WHAT I'm going to do with them.
Maybe a nice sliding door or something.
Old 05-26-2009, 03:29 PM
Kipper's Avatar
Will they not machine out? I actually thought of buying some to replace the bearings....postage kinda crippled the idea......Irvineman (US) has the real V groove bearings..
I'm not keen on cutting vee's
Keith
Old 05-26-2009, 03:37 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
The eBay Ad states they are guaranteed and that they are angular contact bearings.
Return them for a refund if they don't meet the advertised specifications.
Boring them out and replacing the bearings is also viable.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-26-2009, 09:49 PM
lumberjack_jeff is on a distinguished road
If they're angular contact, they should be sloppy until they are preloaded...
... but I'm not sure how you get any meaningful preload on v-groove bearings.
Old 05-26-2009, 10:08 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
i think those are going to be similar to the bearing wheels in the patio door dept at home depot , if they are then they are far too sloppy to do anything with
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 05-27-2009, 09:57 AM
No, the bearings really are THAT bad. I thought I could preload them and at least run true, but the balls "catch" in the race intermittently, so I'm not sure if I want to fight with them or not.
I could machine the rollers for a quality bearing but first, I don't have a lathe, or access to a lathe, therefore it would cost much more using a machine shop to do it, than buying a quality roller from a reputable manufacturer.
I still haven't decided if I'm going to bother with these. I found out yesterday, they won't run on a smaller steel angle, like 1"x1" angle.... The pocket of the v-groove is radiused and causes the roller to ride ABOVE the angle. The larger steel angle, like 3" has a radiused edge that works well, but 3" angle is a bit large to say the least. They are a 90degree v-groove though.
Ten v-groove rollers anyone? C'mon!? $25 right now
Old 05-27-2009, 10:06 AM
asuratman is on a distinguished road
Its just like alibaba and robinhood!
Old 05-27-2009, 10:30 AM
keebler303 is on a distinguished road
1. "Caveat Emptor"
2. "You get what you pay for"
I'm pretty sure they aren't AC bearings. They aren't what you want in this application anyway. People are always talking about AC bearings so people say everything has them so it looks cool and high quality.
Matt
Matt
  #11   Ban this user!
Old 05-27-2009, 11:23 AM
Kipper's Avatar
Originally Posted by keebler303 View Post
1. "Caveat Emptor"
Matt
Matt
Then again some just talk bollocks! "Lapsus Linguac"
Keith
  #12   Ban this user!
Old 05-27-2009, 12:18 PM
1. "Caveat Emptor"
Matt
Matt
It could have just as easily been: "WOW Y'ALL!!! I GOT THE MOST AMAZING DEAL ON SOME HIGH QUALITY ROLLERS WITH PREMIUM BEARINGS!!!"
But, alas..... I'm the putz.
Locating Rollers... PinMan General Metalwork Discussion 0 01-30-2009 01:58 PM
"Home-made" V-groove rollers and rails Gerald_D Linear and Rotary Motion 10 06-14-2008 03:02 AM
Has anyone used crown rollers? jerchi DIY-CNC Router Table Machines 1 10-19-2007 09:54 AM
feeding rollers DrStein99 Linear and Rotary Motion 1 07-25-2006 10:44 PM
Gear rollers Bassbuilder Mechanical Calculations/Engineering Design 15 01-27-2005 06:15 AM
