Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-20-2009, 09:21 PM
John Welden is on a distinguished road
Identify spring type.
What is the name for a spring that works just like a diving board? IE A rod only supported on one end and the other end is allowed to flex/spring in space. Would that be considered a torsion spring?
Thanks,
John
Old 05-20-2009, 09:33 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
John,
I believe you are asking about a cantilever or beam spring.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-20-2009, 11:04 PM
altaic is on a distinguished road
It's also sometimes called a leaf spring when it's multilayered.
Old 05-21-2009, 11:46 PM
Thanks for your help.
Bridgeport clock spring seiz0r Bridgeport and Hardinge Mills 4 11-03-2008 11:37 PM
Spring Winding DIY ? How to MHINK Bending, Forging,Extrusion... 4 02-11-2008 07:34 AM
Gas Spring Specs Chrisjh Syil Products 4 02-09-2008 11:03 AM
Problem fitting a gas spring to X3 daedalus Benchtop Machines 10 10-29-2007 04:52 PM
I need a u-nut / spring nut / j nut ljoe1969 CNCzone Club House 1 02-06-2006 04:12 PM
