| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
| Ball screws and angular contact bearings? I am looking to buy a NSK ballscrew for my z-axis and it come with the ballnut and bearings (which I assume are angualr contact bearings). One thing I have noticed with most ball screws and their bearings is that they have one bearing on one end and two bearings on the other end? My question is: 1) why is this? 2) which end should be pointing down towards the table (ie. should the two bearings on one end be closer to the table or further away and closer to my z-axis motor), or does it matter? Thanks |
| The two bearings on one end are the angular contact bearings. The single bearing on the other end is just a standard ball bearing. This design is meant to trap the ball screw at one end by the two bearings to prevent any linear movement. This linear movement contributes to backlash. The other end is held in the radial direction but able to float in the linear direction to take up movement of expansion and contraction when the temperature changes. You don't want to lock the screw (in the linear direction) on both ends. Normally the end with the two bearings is the end where you will attach the motor to power the screw. With this said it's most of the time at the top of the Z axis.
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| Which Ball Screws to use? | Willyb | Linear and Rotary Motion | 4 | 01-19-2005 09:49 PM |
| Thrust Bearings | chas | DIY-CNC Router Table Machines | 19 | 08-05-2004 07:07 PM |
