Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 05-14-2009, 04:50 PM
Spiral_72 is on a distinguished road
what diameter acme rod?
I asked before, but the discussion got side tracked. )
Is there a chart somewhere, or rule of thumb that tells me how fast I should spin a diameter of Acme threaded rod to keep wobble out?
As of right now I'd like to run steel 1/2" acme, 5ft long at 200rpm, captured on both ends with a ball bearing and a thrust bearing. Any thoughts? What is the max revolved speed of 1/2"?? 5/8"??
Thank you,
Old 05-14-2009, 05:09 PM
Well, never mind. I found it. Supposedly I can spin 1/2" acme over 600rpm.
http://www.nookindustries.com/engine...ticalSpeed.cfm
can stub acme be changed to acme osiris999 General Metalwork Discussion 4 01-28-2009 03:00 AM
Shaft Diameter, LeadScrew Diameter, Motor Torque? cnc-newb DIY-CNC Router Table Machines 8 12-24-2007 03:51 PM
Shaft Diameter, LeadScrew Diameter, Motor Torque? cnc-newb General Metal Working Machines 0 12-14-2007 10:25 PM
.249" diameter acme screw? Macht_Tot General Metalwork Discussion 11 08-07-2007 08:20 PM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 06:47 AM
