Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 01-27-2005, 02:24 AM
dowling177 is on a distinguished road
Timing belts for x and y axes (what pitch?)
I am building a CNC router table to cut 3/4" plywood. I am looking into getting a belt that is an 1" wide and has a pitch of 3/8" (is this pitch too big)?
also what are normal prices for these belts I might be paying approx $85 CAN for a 10ft length
Thanks for the input
Old 01-27-2005, 07:49 AM
Moondog is on a distinguished road
Hey Dowling...
Plywood... for boats?.. from the lenght of the belt.. I assume it's for the X Axis.... how are you driving it?...
Pitch... you wouldn't want anything less than 10mm. $85.00 sounds reasonable. Maybe a T10 or a T5.
3/8 pitch?... suitable?.. depends on the size of your pulleys... on a large pulley... 300mm +.. that would be fine... you need to ensure that there are sufficient teeth on the pulley when mounted... there is a formulae.. can't remeber... something like 40% of the teeth engaged?.... if your pulley is too small for the belt then the teeth won't engae properly.. when you use smaller pulleys like on the Z axis a good pitch is 5mm...
hope that helps
cheers
Old 01-27-2005, 10:12 AM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
I used a 1 inch wide belt, 5mm pitch, for my X axis. The belt rides on 26T pulleys. It is geared down 3.6:1 at the motor.
This gives a resolution of:
5mm*26t = 130
1mm/130 = 0.0077
motor is 200 step and gearing 3.6:1 so:
0.0077*200steps = 1.54
1.54*3.6 = 5.544 motor steps to move 1mm
1/5.544 = 0.18mm is the minimum movement. Or .007"
When I build my all belt drive machine I'll use smaller pulleys on the movement belt to give more resolution. And aim for a 4:1 reduction also for more resolution.
Speed is no problem. My 110 OZ motors are running at 65% of rated current and I'm getting rapids of 800 IPM. So can afford to trade off some speed for extra resolution.
I hope that helps you make your choice of what pitch and pulleys to go with.
Regards Terry.....
http://www.terry-is.f2s.com/
Questions about timing belts & gears rc-cellar Mechanical Calculations/Engineering Design 1 04-28-2005 12:09 AM
Planetary gearhead vs timing belts Swede General Metal Working Machines 4 03-27-2005 09:19 PM
Timing Belts chas DIY-CNC Router Table Machines 1 01-19-2005 10:03 AM
Cheap Source for Timing Belts and Pulleys? samualt DIY-CNC Router Table Machines 10 09-10-2004 07:41 AM
Timing belts.....what type do you use? chozo DIY-CNC Router Table Machines 4 08-27-2004 10:19 PM
