| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
I want to design an adapter plate to mate a Nissan VH45DE V8 engine to the 5-speed manual transmission in the Nissan 300zx. A good friend of mine has a water jet, so if I can get accurate enough measurements I can design and build a prototype to make the final corrections during mock up. So what can I do to accurately map out each of the bolt hole locations as well as their relation to the input shaft / crankshaft pilot bushing. I work in a automotive garage, so I may not have access to the most accurate tools... |
| I use a bridgeport with a DRO to measure stuff like that. Use an indicator and tram each hole, if they are threaded, put an allen head bolt in the threaded hole and measure the head. You probably won't have enough travel if you use a BP or similar knee mill, locate off of the crank pilot, measure everything you can, flip it over and measure everything else, measure a couple of them twice so you can match it up when you do your CAD work. It's a PITA, but it's easy, if you have a mill with a DRO anyway. MC |
So, would it be better to take a VG block (the engine the transmission comes from) and use it to get the measurements? The lower mounting holes are bolt on brackets that would be simple to fabricate... I may have solved this myself, well I needed something to redirect my thought path! |
I would use a block if at all possible, would be easier since you should have more surface area for it to lay flat, vs a trans bellhousing. MC |
| I found the bell housing sat nicely on the milling machine, but it is not my piece of equipment so I am not familiar with the tooling for it. I am not that experienced when it comes to machining, I just understand what the technology does... So this is a learning experience for me. |
Best bet is ask your machinst to teach you how to tram holes, if he weill let you borrow his indicator ![]() Pick a hole, or the crank pilot, make that 0,0 and record the location of all the other holes in relation, and use this information to make your CAD drawings. |
| Just another little hint.. Rather than a capscrew, use a tap. The shank is smooth and ground, more accurate to the thread than a capscrew head. Should also fit tighter in the threaded hole. $0.02 US Dick Z
__________________ DZASTR |
So basically thread the tap in, then align the milling head? |
| MC |
#10
| The information posted here has been very helpful. Hopefully this weekend I can get both blocks onto the milling machine |
#11
| MC |
#12
| Hi NavyF350, the bolt holes are CLEARANCE, that is they are a loose fit, .010" to .015" clear, but there are two dowel holes on either side of the bell housing that allign the plate with the engine and bellhousing. You can mark out the bolt holes, using regular marking out methods as they're clearance holes, and the dowel hole positions are picked off the engine block back and bell housing, and transferred to the plate. Ten to one the dowel holes on the engine back won't match the bell housing so you will have to either drill and ream new dowel holes (2) in each, or drill and ream the plate to suit both existing dowel positions. Ian. |
| Need Help with some Gear Measurements | Kain | Mechanical Calculations/Engineering Design | 9 | 07-16-2009 10:24 PM |
| telecaster diagram with measurements | woodman08 | Musical Instrument Design & Construction | 3 | 03-18-2009 11:09 PM |
| Powersupply questions (took some measurements)... | radioactive | General Electronics Discussion | 13 | 03-03-2009 12:12 PM |
| Do measurements really matter? | deleteallusers | Linear and Rotary Motion | 2 | 02-10-2007 10:37 AM |
| Hairline measurements.. | Rekd | CNCzone Club House | 9 | 08-27-2003 12:56 PM |
