| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
I’d like a little advice choosing an acme rod. I plan to use a delrin or similar nut. I use these steppers: 103H7126-0110 - 1A, 1.27Nm (179.8oz/in) holding torque I measured the top speed of the stepper, before it started chattering, at 135rpm. The stepper is installed on my current CNC, so it was under a minor load driving the screw. I’d like to design a new CNC capable of 200 inches per minute. A little calculating gives me 1.47 inches per revolution. Is this reasonable? Is ½” acme rod a good choice at 130 rpm or should I go bigger? What pitch? Single start? Multi-start? I can do the single start math, but I don’t understand the multi-start stuff. Also, 130rpm seems awful slow. Should I suspect a problem with my stepper driver? Or is this reasonable? |
| The right motor - drive - power supply combination should get you around 1000 rpm. You probably don't want to try to achieve your goal speed at 135 rpm.
| You didn't say what drives you're using, but I think most people here are getting 500-800 rpm out of their motors.
| This Vexta still has 30% of it's torque at 2000 rpm, as an example. It's a 6A motor with very low inductance, and the torque curve is running it at 60V.
| Need Help!- Choosing the right part | prabb | DIY-CNC Router Table Machines | 4 | 02-21-2009 07:57 AM |
| can stub acme be changed to acme | osiris999 | General Metalwork Discussion | 4 | 01-28-2009 03:00 AM |
| Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help | pandiyan.innova | CNCzone Club House | 7 | 11-16-2006 06:47 AM |
| Need help choosing | lmartin1001 | Benchtop Machines | 2 | 10-13-2006 02:24 AM |
| what acme tap do I need for the Enco ACME rod? | AJ_Mac2001 | DIY-CNC Router Table Machines | 15 | 03-08-2004 08:24 AM |
