Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 01-23-2005, 08:51 PM
Bassbuilder is on a distinguished road
Gear rollers
I have been thinking of making a cnc wood router for some time now. As I am a college student, I don't have much money therefore I'm looking at cheap ays of building one. I had a thought not too long ago on how to make one really cheap and very accurate. On a standard cnc machine, the axi operate on twin slides and a ball screw to drive it. the problem here is that these polished slides are very expensive along with the pillow blocks. The ball screws are also very expensive. This is what I thought. If one were to make a machine that operated on a rack and pinion. A person could extend the machine if needed simply by adding more racks and the only things to be bought would be the gear and the track, which, arent' that expensive. This also would solve the problem of axis skewing, making the machine more accurate. Tell me what you think...
Old 01-23-2005, 09:16 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
All you've done is replaced the ballscrew with two sets of rack and pinion. Which still leaves your statement:
Originally Posted by Bassbuilder
The problem here is that these polished slides are very expensive along with the pillow blocks.
You still need to use these parts, or buy/build something cheaper.
To extend the machine you still need to add the rails/carriages or ground rod. Whatever you use to guide the linear motion.
The rack and pinion is just part of the drive train. Same as a ballscrew, timing belt or threaded rod.
I don't see that using rack and pinion will save you a lot of money.
Regards Terry.....
Old 01-23-2005, 10:28 PM
ger21's Avatar
I'm not sure if Terry completely understood your intent, but he's right. A lot of people use rack and pinion instead of leadscrews, but they can't replace the bearings/ guides/rails...
Old 01-23-2005, 10:32 PM
I think you missunderstood me. Instead of the the device operating by sliding on the bars, it will travel on the rails like a train. It would sit on 4 gears, one set will be connected to the one on the other side by a rod. A motor then drives the rod, moving the machine.
Old 01-23-2005, 11:06 PM
MrBean's Avatar
Gold Member
Yeah. I guess I'm missing something. Rack and pinion is good for linear motion, but what is keeping it in a straight line as it's moving at 100 IPM with the attached Y axis simultaneously throwing a cutting spindle back and forth. Also, what stops the machine lifting off the rack as you plunge a 1/2" cutter into your material.
I'm not trying to run your idea down. I'm merely pointing out the fact that rack and pinion drive will still need some kind of linear guide.
If I've missed something, then perhaps a picture or drawing of your idea would be of benefit.
I, like many others on here, have been looking for a cheap linear guide system. So far the pipe and skate bearing combo looks about the most reasonable "cheap" system. I'm working on a design, based along the lines of the pipe and skate bearing combo. Still a little way to go with it, but it's looking good so far.
Regards Terry.....
Old 01-23-2005, 11:30 PM
esmiller is on a distinguished road
Lightbulb
Regards Terry.....
The skate bearing idea can be quite cheap if you watch E-bay too.. i just bought 100 bearings for about $28 w/ shipping. Not bad, as i will give me plenty to play with for possible future designs as well as robotics usage.
Now I just need to locate a source for the pipe, and check prices on it..
the MDF looks like it will be about $22 for a 4X8 sheet.
Looking for info on drilling & tapping holes in MDF though, if anyone can help. I will also post this question as its own topic.
Eddie
Old 01-23-2005, 11:39 PM
Good point with the lifting up. I would have to find some way to anchor the slides down.
Old 01-24-2005, 12:06 AM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
And, even cheaper if you hit the Goodwill stores in your area. I routinely pay between $.50 - $1 per pair for inline skates. 1 pair yields 16 bearings...2 per wheel. Just look for practically new ones...often someone's kid gets a pair, falls down, and never skates again. Or my personal favorite, someone overweight with a New Year's resolution...almost never used. (I can say this, because I've done it myself)
The bearings are easy to remove from the wheels, and the wheels make good bearing mounts.
Home Depot. Check the "scraps" next-to or underneath the pipe threading machine. They often just throw them out, or will price them so cheap that you can't refuse. Find someone who isn't afraid to get creative (a "closet" engineer) and chat them up...once you find a helpful person, tell them about your project, and they'll often find parts for you at minimal or no cost.
Lowes will behave similarly, but has certain company policies that don't allow quite as good a deal to be brokered, in my experience.
EXAMPLE: I paid $2 for a full sheet of MDF that had been improperly cut into 3 appropriately sized strips. 3 pieces of 16" x 96" x 3/4" MDF was quite useful to me.
Tapping MDF isn't a problem.
I know it sounds too simple, but just drill the appropriately sized hole, and tap it with a standard tap. The granular structure will crumble a little bit, but the threads will be just fine. A drop or two of cyanoacrylite glue (super glue) will penetrate into the threads and toughen them up, though it's not strictly necessary.
-- Chuck Knight
Old 01-24-2005, 12:40 AM
Lightbulb Tapping MDF
-- Chuck Knight
I have seen this remark about the cya (Super Glue) before.. do you just drop it into the hole, or try to let it run down the inside edges of he hole, or do you fill the hole, and re-drill it and tap it afterward?
I know that sounds dumb, but want to make sure what i am in for here
Any idea how many sheets of MDF I am looking at.. I am thinking the basics can be done with a single 4X8 sheet, but I may be wrong *Grin*.. I usually am..
Eddie
Old 01-24-2005, 12:43 AM
Torsten's Avatar
Torsten is on a distinguished road
Cool
What you would get is gone be more like a car driving over the tressels.
Bump, bump, bump kind of motion.
Gears do not make good wheels.
  #11   Ban this user!
Old 01-24-2005, 04:35 PM
dwwright is on a distinguished road
Tapping
Eddie
Be careful with larger taps when backing them out as they can cause splits in the MDF. I usually mount a clamp accross the mdf to keep it from expanding. Also with the small taps ( 10-32 and smaller), you can drill the holes and then put the tap in the drill, makes a much faster job than hand twisting the tap in.
  #12   Ban this user!
Old 01-25-2005, 07:31 PM
andy_ck87028 is on a distinguished road
If it helps, I've come up with what I think is the cheapest way of building CNC router rails without sacrificing robustness, durability, precision. I have gone down the skate bearing path but instead of a circular rod, I am using a square section beam of dimensions 50mm high, 25 mm wide and 2.5mm thick walls.
The beams are my guide rails with the same assembly for x and y except x is anchored to the base. Each assembly (a pair for x and a pair for y) has 2 skate bearings (A) sitting on top of the beam taking the weight; 1 skate bearing under the beam (B) stopping lift caused by using heavy duty cutters and 2 skate bearings on one side only (C) stopping lateral drift and skew. (5 per assembly totalling 20 all together)
The beam is cheap and easy to mount. If I have a problem with precision, I'll get the beams milled.
I am using threaded rod - very, very cheap and fixed at both ends with a drive belt pulley arrangement to achieve movement (rods stationary with drive mechanism on the assembly). I thought long and hard about using a flattened drive belt as a form of rack and pinion but I lost too much on the gearing and precision benefits of threaded rod.
As the drive assembly is to be timing belts and pulleys, the only backlash point will be on the threaded rod which I can overcome with a simple backlash eliminator.
I have attached a drawing of the guide rail assembly. I hope people can understand it. Note that it only works for x and y as it needs an opposing pair to make the inner skate bearing work. My z axis is still waiting further thought.
I reckon guide rails, threaded rod and assembly (less drive) including skate bearings will cost under $200 and only requires a benchpress, an angle grinder and spanners. I have yet to guestimate the drive assembly but I'll be delighted if I can get that under $200.
Hope the attachment works ... first time!!
Cheers
Andy
Name:	guide rail drawing.jpg‎
NASA gear bearing by mister Vranish wolphje General Metalwork Discussion 1 07-28-2005 02:28 PM
gear pitch 2muchstuff Mechanical Calculations/Engineering Design 5 04-02-2005 09:04 AM
Gear reduction DragnsBane Stepper Motors and Drives 3 11-11-2004 06:36 AM
Stop Buying Expensive EDM Pinch Rollers Jim Abbett Product Announcements & Manufacturer News 0 09-29-2004 04:51 PM
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 9 04-17-2004 04:58 PM
