| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Hi forum, I'm working with some metric spur gears in azetal and steel, and need to know how far I need to place them from each other. Module 1 gears: 80 teeth azetal and 10 teeth steel. Calculated distance between centers without backlash: 45mm. Module 0.7 gears: 75 teeth azetal and 12 teeth steel. Calculated distance between centers without backlash: 30.45mm Now I need to know how far to place the centers so there will be a bit of backlash to avoid overloading the gears. Also I don't know how much backlash I need, but I just need to know the exact distance between centers for both gear sizes (module 1 and module 0.7). Is there a table for this somewhere on the web? Something like "add 0.1mm distance between centers for module 0.7 gears". Thanks. Best regards, Futterama |
| I believe you will find the information you are looking for here. http://www.roymech.co.uk/Useful_Tables/Drive/Gears.html John |
| The center distances would most commonly be left accurately at the calculated seperation distance. Backlash is created by a slight overcut of the gear tooth's whole depth. Commonly, one will use a gear tooth vernier caliper to measure the chordal thickness of the tooth right on the machine. However, these measuring tools do have limits on how small of a tooth they will measure. If you cannot get a caliper in to the pitch circle depth (the addendum deep), then you'd probably need to spring for a 3 wire measurement across the gear. There are tables or formulas in Machinery's Handbook to help you figure the pin diameter and the chordal measurement, so that you can infer the pitch thickness of the gear tooth based on how far a wire of a particular diameter fits down into the gear tooth space. The ideal wire is calculated to make contact near the addendum depth, which is where the pitch circle is located.
| A workable method to get the mesh right is to put some plastic food wrap in the mesh between gears and tighten the movable one down, then run the plastic out. There is a product for that, though the name escapes me...
__________________ Mike Visit my projects blog at: http://mikeeverman.com/ http://www.bell-evermannews.com/ http://www.bell-everman.com |
Plastigauge.
| Making a four stage spur gear box? (how to ) | youthreewire | Mechanical Calculations/Engineering Design | 14 | 02-26-2009 10:11 PM |
| ..the teeth on a pinnion spur gear... | malJohann | Mechanical Calculations/Engineering Design | 4 | 07-13-2008 05:22 PM |
| Simple spur gear design | wildcat | General Metalwork Discussion | 9 | 05-23-2008 07:17 AM |
| Spur gear availability? | 2fst4u | CNC Plasma and Waterjet Machines | 3 | 04-02-2007 09:46 AM |
| Spur Gear / Gear Rack | ckrantz | Linear and Rotary Motion | 12 | 12-07-2006 12:06 AM |
