Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Calculating gear ratios?
    Site Owner CNCadmin's Avatar
    Mar 2003
    This is to benefit myself and others. What is the formula for calculating gear ratios? Also for calculation the inverse of pie?
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Moderator HuFlungDung's Avatar
    Mar 2003
    ratio of a compound gear set = (product of driver gears)/(product of driven gears)
    inverse of Pi = 1/Pi
    Dec 2003
    On a related topic, if you require information on ratio of timing belts, including the centre distance calculator etc , Stock Drive Products have a CD called the 'World of Timing belts' they may have it for download now.
    BTW the first half of their free gear catalogues read like engineering manuals on gears.
    Al
    Dec 2004
    Quote Originally Posted by Al_The_Man
    Al
    Actually the center distance calculator etc can be found on SDP-SI's homepage. And yes, the catalogs are a breath of fresh air arent they?
    Dylan
    Mar 2003
    That's OK, but the site would be a lot better if you could put in the ratio and it would give you all the combinations of pulleys that can be used. That page is really just for calculation the belt length for a give pulley combinations. When you're trying to get a gear ration based on pie for a belt driven system it's takes a little bit more work.
    I found this bit of info- http://www.sdp-si.com/D260/PDF/part1.pdf
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Oct 2003
    Sweden
    Quote Originally Posted by CNCadmin
    *snip* What is /.../ the inverse of pie?
    That would be carrots. (Sorry just couldn't resist it .)
    Arvid
    Aug 2004
    Brazil
    Hey Admin: Nice document! Thank you!
    Jun 2008
    india
    where can i find the Gear ratio calculator software??????
    May 2008
    Quote Originally Posted by sumit.ghatak View Post
    Gear ratio for what?
    Mike Visit my projects blog at: http://mikeeverman.com/
    http://www.bell-evermannews.com/ http://www.bell-everman.com
    Jun 2008
    india
    for all kind of gears I need the gear ratio calculator
    May 2008
    Can you be more specific?
    A gear ratio is number of teeth over number of teeth. Asking for a gear ratio calculator is like asking for triangle point counting software.
    I am not trying to be insulting. ;-) I'm sure it is a language thing.
    Have you followed the links below? What are you trying to do?
    Jun 2008
    india
    Hi there Mike.
    you see ,I am no Engineer my self. the gear ratio calculator I need is for my father ,he is an engineer himself but he is currently out of station,and it is very difficult for me to arrange the software for him. well let me tell you some thing....the software comes with Dr. Gears website I have tried it, but it seems to a trial version and I need A full version ,,,now my request is can you tell me where can I find the full version ,
    thanks buddy
  • Page 1 of 2 12 LastLast
    1. Basic Bevel Gear - Milling a valley for gear teeth
      By ngr1 in forum General CAM Discussion
      Last Post: 04-05-2012, 10:55 AM
    2. NASA gear bearing by mister Vranish
      By wolphje in forum General Metalwork Discussion
      Last Post: 07-28-2005, 02:28 PM
    3. gear pitch
      By 2muchstuff in forum Mechanical Calculations/Engineering Design
      Last Post: 04-02-2005, 09:04 AM
    4. Adding a manual gear change call
      By MILLMANM in forum Post Processors for MC
      Last Post: 01-04-2005, 11:05 PM
    5. Gear reduction
      By DragnsBane in forum Stepper Motors and Drives
      Last Post: 11-11-2004, 06:36 AM
