Results 1 to 6 of 6
Thread: Need method to apply thread Lubricant (high volume assembly)
    Apr 2005
    I am looking for a good solution to apply thread lubricant to various hardware quickly and cleanly. Current process takes to long and often results in lubricant on hands which mark final product which can't be easily cleaned. I"m thinking almost a lubricant well to dip hardware then something to remove excess. Anything on the market like this, or am I just going to have to end up making my own? current process consists of laying out hardware, taking lube bottle with small tip to apply to individual bolts then rolling to ensure good 360 degree coverage, messy and time consuming. Lubricant viscosity can be varied based on application method needs.
    Any suggestions welcome.
    Dec 2006
    Have you thought of using feltpads or cotton swabs that would bring the lubricant to the bolt thread?
    Best regards
    Bruno
    Registered M100's Avatar
    Oct 2006
    UK
    A paintbrush
    Jan 2008
    Try this
    What about an airbrush setup. Cheap to purchase, and accurate. This would probably work if your lubricant is thin enough.
    Chris
    Registered Superman's Avatar
    Dec 2008
    Krypton
    What about a syringe ?
    with a foam pad glued around the stem , similar to a liquid boot polish applicator
    Aug 2008
    UK
    Bill
    1. High Power UHU Thread (HP.UHU)
      By contactirfu in forum UHU Servo Controllers
      Last Post: 12-24-2008, 07:06 PM
    2. Method to internal/external thread ?
      By PeteGallo in forum General CAM Discussion
      Last Post: 04-03-2007, 10:50 AM
    3. What's the best method to turn a thread and a 3/32" bore concentric?
      By Darc in forum General Metal Working Machines
      Last Post: 10-27-2006, 07:34 AM
    4. High pressure low volume water pump
      By DDM in forum DIY CNC Router Table Machines
      Last Post: 06-25-2005, 03:36 AM
    5. High Volume Vacuum Tables
      By azsigns in forum DIY CNC Router Table Machines
      Last Post: 02-27-2004, 03:04 PM
