Results 1 to 2 of 2
Thread: To Design A Turbine
    Jul 2008
    India
    To Design A Turbine
    theres a 3 HP pump having foll specifications :
    Flow Rate : min= 2.2 litres/sec max= 4.1 litres/sec
    Head Range : 15 m - 25m
    overall efficiency : 40%
    RPM : 2840
    According to situation pump is on ground & has delivery head of roughly 1m & delivery pipe dia 6 cm. Now i have to DESIGN A TURBINE(i think Francis wud be gud) at its outlet to generate electrical energy by coupling a dynamo or electrical generator to turbine's shaft.
    CAN ANYONE GIVE ME A BRIEF IDEA?
    Jul 2008
    New Zealand
    If 40% efficiency is the goal (that's very low) then flat paddle blades will probably do the job.
    You'll need to size the scroll housing to give you a flow speed at the tip that is higher than the turbine runner tip speed, I'd shoot for 1.5 times that for a start.
  1. pics of my turbine
    By gv71 in forum Jet Engines and Ram Jets
    Last Post: 01-17-2013, 04:10 AM
  2. Diy Wind Turbine
    By diarmaid in forum Hobby Discussion
    Last Post: 03-23-2011, 03:10 PM
  3. Turbine power
    By 2muchstuff in forum Jet Engines and Ram Jets
    Last Post: 08-02-2007, 10:05 AM
  4. turbine model
    By da21 in forum Jet Engines and Ram Jets
    Last Post: 07-18-2007, 12:05 AM
  5. China Turbine Zhongneng Turbine Oil Purification/Oil Purifier/Oil Filtration
    By tracy127 in forum Product and Manufacturer Announcements
    Last Post: 10-10-2006, 04:19 AM
