Results 1 to 11 of 11
Thread: "D10"tolerance on a bored hole
    Jun 2006
    united states
    Anyone have the conversion of this tolerance call out "D10" it is being used on a bored hole 30.025 diameter????????
    Dec 2007
    check this out....
    regards
    Attached Files Attached Files
    Can't Fix Stupid
    Jun 2006
    united states
    Thanks for the direction
    I also found another web site after posting "Maryland Metrics"
    Mar 2008
    30.025 mm hole and a D10 (+80/+180) tolerance????????
    Typical for somebody not knowing his way around metric. 30 D10 would be just fine.
    One can see how much being illiterate in metric is costing us. I hope they do not sent this to any other country - not a good presentation of American engineering.
    Juergenwt
    Dec 2006
    Actually the information is in thousands of mm so the tolerance would be +.080/+.180mm
    Best regards
    Bruno
    Mar 2008
    Bruno -look at it again. Juergenwt
    Dec 2006
    juergenwt,
    nominal diametre sizes are in mm, tolerances are in .001mm.
    I took you +80/+180 for granted and I shouldn't have.
    A 30.025 mm hole is in fact a 30mm nominal hole with a tolerance of +65/+149 the fundamental lower deviation is +65 for a D tolerance the IT grade is an IT10 of +84:
    MAX hole size = min hole size + IT => 30.065mm + .084mm
    MAX hole size is : 30.149mm
    you can refer to machinery's handbook 27th ed page 684 "British Standard Limits and Fits" and page 687 "British Standard Fundamental Deviations for Holes"
    If you transfer back the min-MAX hole sizes to the 30.025mm hole the tolerance is +40/+124 microns (.001mm) so the min-Max hole are as above.
    This is how I've learned it, If I tripped over something, please let me know where I did.
    Best regards
    Bruno
    Mar 2008
    Hello Bruno-direct from the ISO tolerance table: D10
    Over 18mm and up to 30mm - +65µ / +149µ
    Over 30mm and up to 50mm - +80µ / +180µ
    30 D10 is over 30mm.
    The +80/+180 tol. applies.
    Sorry Bruno - I do not have a British Standard available to me in the US.
    Pls. let me know if you agree.
    What I really think is that somebody not familiar with metrics wanted to cover his rear and put these dim's (30.025 D10) on a print. It happens quite often in the US and I can understand why. People can not think in metric and it will take a generation to overcome this problem - providing we can get past our politicians and change our school system to teach nothing but metric. But that would be asking a lot.
    Thanks Juergenwt
    Dec 2006
    Juegenwt,
    Tolerances are applied to the NOMINAL diameter, a bored 30.025mm IS a 30mm NOMINAL hole size tolerances are +65/+149. That's theory.
    Practically D10 is only half of the puzzle, the hole will mate to a shaft according to a specific shaft, if the shaft is a purchased item, then a reverse calculation must be made according to the fit tolerance and then the hole tolerance must changed according to the fit tolerances. Confused?. It's part the "YOYO" calculations required for getting the correct fit. That not only applies to ISO standards (metric) but also to ANSI standards (imperial).
    The only thing that is really complicated in the ISO standards of measurement it's fit tolerances in both shaft and bore tolerances, there are too many exceptions you would believe they were written by politicians.
    Best regards
    Bruno
    Gold Member
    Dec 2004
    Newtown, CT, USA
    Quote Originally Posted by juergenwt View Post
    Thanks Juergenwt
    NO... 30 D10 is NOT over 30mm. It is equal to 30mm. So it would seem that +65/+149 applies. But 30.025 IS over 30mm. In that case, +80/+180 would apply.
    That implies one cannot simply write 30 D10 instead of 30.025 D10 because they mean different things.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Mar 2008
    I guess the real question is whether 30 D10 is over 30.000 or not. If the nom. dim. is 30.000 than it looks like +65/+149 is the correct answer. I would like to thank everybody for taking part. Thank you - juergenwt
    1. boring a .875" hole 3" deep in 304SS
      By mc-motorsports in forum General Metalwork Discussion
      Last Post: 04-15-2008, 03:57 PM
    2. Has anyone looked at the "JET" or "Shop Fox" manual machines?
      By boosted in forum General Metal Working Machines
      Last Post: 03-04-2007, 10:33 PM
    3. Smallest "clean" hole size?
      By Scratch in forum General Waterjet
      Last Post: 06-23-2006, 11:15 PM
    4. Vertical system "jerks" and "bangs"??
      By REVCAM_Bob in forum Servo Motors and Drives
      Last Post: 06-12-2006, 10:09 AM
    5. Add "View New Posts" to "Main Menu"
      By Mr.Chips in forum Forum Questions or Problems
      Last Post: 04-21-2004, 11:54 PM
