Results 1 to 12 of 12
Thread: Math Wizard..a little help please? 11-agon??
    Registered teamtexas's Avatar
    Aug 2007
    I'm trying to figure out the angle of the pieces on an 11-agon (I think you call it). What I have are two circles, the inside one is 48" and the outside one it 72". I want to make 11 stones fit together to make this ring and I need to know the angle of the cuts between the stones.
    Dan
    Dec 2007
    Hi: see atached
    have fun
    Attached Thumbnails Attached Thumbnails Math Wizard..a little help please?  11-agon??-11agon.pdf
    Can't Fix Stupid
    Apr 2007
    Take a look at this
    Attached Files Attached Files
    Dave
    "updates always change the feature you need most. "
    Aug 2007
    Thanks to both of you! Thats just what I needed!
    Jun 2005
    Why not just say: 360 / Segments^2 = 360 / 22 = 16.3636 or 90-16.3636 = 73.6363
    Jul 2003
    New Zealand
    Quote Originally Posted by jhudler View Post
    Why not just say: 360 / Segments^2 = 360 / 22 ........
    When I went to school 11^2 = 121
    Jul 2005
    Quote Originally Posted by teamtexas View Post
    I'm trying to figure out the angle of the pieces on an 11-agon (I think you call it).......Dan
    Courtesy of Google and Wikipedia.
    A hendecagon is an eleven-sided figure.
    Aug 2007
    Thanks Greg, although I'm not sure I can pronouce it!
    Dan
    Jun 2005
    Quote Originally Posted by Kiwi View Post
    I think the proof defined defined the typo smarta$$.
    Jul 2003
    New Zealand
    Well is your formula correct or your answer correct?
    Jun 2005
    well what do you think!
    Jul 2003
    New Zealand
    I know your formula is wrong.
    1. math help
      By the4thseal in forum General CAM Discussion
      Last Post: 08-28-2007, 10:09 AM
    2. Nesting Wizard, Mach3 internal wizard.
      By thuffner3 in forum Mach Software (ArtSoft software)
      Last Post: 03-04-2007, 09:38 PM
    3. Math help
      By wcarrothers1 in forum DIY CNC Router Table Machines
      Last Post: 10-20-2006, 07:30 PM
    4. Need some math help...
      By kanankeban in forum Mechanical Calculations/Engineering Design
      Last Post: 04-03-2005, 04:27 AM
    5. Need help with math
      By replicapro in forum General Metal Working Machines
      Last Post: 07-27-2004, 10:08 PM
