Pc = KpCQW
Kp = .90 for rolled aluminum
C = 1 (For .3mm/rev)**
Q = 2.91096 Q = V/60ƒd
V = 286.512
ƒ = .3048
d = 2mm
W = 1
Pc = 2.61986 Kw or about 3HP
I figured that if I just didn't take as deep of a cut per revolution. I would be able to reduce the HP needed. Right? Or at least I thought. The problem is if I take .15mm/rev C now = 1.2. If you redo the equation. you're now needing 3.14348 Kw. Why do I need more power to take a smaller cut??
LinkBack URL
About LinkBacks
