| Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations. |
Hi, I'm looking for a company that can make 5"W x 8"L x .50 thick steel plates which have the texture of a file on one side and are (close to) perfectly flat on the other. Is it possible to cast such a piece? This would have to be mass produced. I'd appreciate any ideas. Thanks, Russ |
| I think you will find that it is impossible to cast a file texture surface in steel. Files are cut to that form; actually it is a cutting and deforming process. It is possible that you could get what you are asking for by a powder metallurgy process which can provide very fine detail but your volumes would need to be very high and the upfront cost for the sintering dies might be very high assuming it is possible to do that size of part. If you have to have actual file teeth in hard steel so they can cut like a file I think the file cutting process will be needed. If you just need a textured surface I expect the best approach could be looking at some form of knurling process either hot or cold.
| Russ, How coarse and what is the profile shape? Geof is, as usual, correct about how file making process. For some reason I have a different vision in my head of your parts. You mentioned mass produced? How many is a mass? Some of those paper mill pulp grinder plates are not all that coarse, but they do grind the surfaces after casting to produce sharp edges on the serrations and for uniform thickness.
__________________ DZASTR Last edited by RICHARD ZASTROW; 10-23-2007 at 05:17 PM. Reason: spelling |
| Hi Richard, Thanks for your help. I need the surfaces to be made in varying degrees of coarseness, and I by "mass produced" I mean tens of thousands of pieces. The problem that I'm having is finding a manufacturer who can produce plates that are .50-.55 thick and are perfectly flat after they are hardened. |
| If you are in the tens of thousands you may be in powder metallurgy territory.
| Russ, Any shop with a Blanchard type grinder, double-disc grinder or flat platten belt grinder would love your parts. Probably inexpensive in large quantities as well. In fact, I bet some steel foundries have that equipment in their cleaning or second op rooms.
__________________ DZASTR |
#11
| We'll have to explain that to a local foundry. They've been doing that to chilled iron pulp grinder plates for more than 50 years. They do have to turn them upside down to get both sides though. The volume does justify the fixturing. I still don't know the specifics of Russ's part shape or serration edge requirements.
| Ren Shape | cadman | General Material Machining Solutions | 2 | 06-02-2009 07:18 AM |
| New vs old cast iron, new vs old steel ? | vroemm | Mechanical Calculations/Engineering Design | 18 | 11-08-2008 02:09 AM |
| die for pressing steel sheet into U shape | Runner4404spd | Diemaking and Diecutting | 16 | 06-20-2008 12:42 PM |
| How/what machine to shape a thin stainless plate to become a "half" egg shape ? | Calico | General Metalwork Discussion | 5 | 03-24-2007 10:40 AM |
| RFQ – cnc-Shape cut out of ¼” MDF Board | njtermite | Employment Opportunity | 6 | 11-28-2006 07:08 AM |
