Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 10-09-2007, 08:58 AM
KENNETH BROWN is on a distinguished road
demag
new here sorry if wrong froum trying to found out about demagnitzers
would like to build one for large parts
Old 10-09-2007, 09:33 AM
svenakela is on a distinguished road
How large part do you intend to work with?
I'm not sure, but maybe you'll get better response in the Electronics forum?
Old 10-09-2007, 09:45 AM
thanks will try different forum the parts are large gear blanks
400.mm dia. x 350.mm long this is the largest part i would need to demag
Old 10-09-2007, 11:08 AM
Al_The_Man's Avatar
I imagine they consist of high energy AC 50/60hz coils, if so they possibly could be constructed using a welding transformer supply?
This is essentially what is used for crack & defect detection.
Old 10-10-2007, 12:35 AM
lgalla's Avatar
lgalla is on a distinguished road
Must admit don't know how to build one,but loudspeaker repair shops have mag-demag service.Sometimes it is cheaper to send out than attempt to do it yourself.
http://www.speakerrepair.com/services.html
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 10-10-2007, 05:17 PM
atifeh is on a distinguished road
I have a primary winding of a scraped transformer, the wire is 1mm thick and about 1-2 kilo in weight. The opening is about 30x50 mm . I simply connect it to 220VAC and demagnet tools and parts. It only takes seconds. In order to make for a 400mm dia. you can wind a coil to your requirement. The only issue will be the time to demagnetize. If you need for example to demagnetize pipe ends for welding, then you need to elaborate more. There are lots of sources for its calculation, just google demagnetizing.
Hope that helps
Nader
