Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-29-2007, 10:10 AM
ssphoenix is on a distinguished road
6" long drill
Sorry if I post this in the wrong forum. I am new here and need to find this answer. I need to drill a 4mm hole for about 6" (approx 150mm) in steal (rebar steal). is it possible? I can't turn it (has to be done from one direction)
Help would be greatly appreciated.
Old 09-29-2007, 01:59 PM
neilw20's Avatar
neilw20 is on a distinguished road
Lightbulb A Gun Drill will work
Look here: It is a starting point to learn the ins and outs of long holes.
http://www.sterlinggundrills.com/dee...undrills.shtml
You need high pressure compound up the spindle. I have used 600 PSI! (5HP)
3/4" hole a meter long in K1045 STEEL. 1 1/4" per minute 1200 RPM
At 4 mm you would need at least 5000 RPM
You need a sealed spindle, and a way of coupling compound into the system.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
How can I drill a 2" hole through a window? garagefela Glass, Plastic and Stone 25 01-29-2007 08:00 PM
Need Extra Long Ball End Mills (12"overall length) CADkathy Toolgrinding & Toolgrinding Machines 2 02-17-2005 10:54 PM
drill rod longer than 36"? where? CNC Darren DIY-CNC Router Table Machines 3 09-25-2004 09:17 PM
Will 63" long Rail sag without using shaft support? starCNC General Metal Working Machines 5 08-04-2004 09:29 AM
Drill & Tap Combination "DRAP" Machine1 Hard and High Speed Machining 9 02-10-2004 08:01 PM
