Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Mechanical Calculations/Engineering Design
Mechanical Calculations/Engineering Design Discuss general mechanical design and mechanical calculations.
Old 09-27-2007, 10:22 PM
307startup is on a distinguished road
Durabar for machine components, from scratch
Does anyone on this forum have any experience using Durabar (continuous cast-iron) or a similar product? I machine ductile iron about once a week at work and other than than abrasive grit that passes for chips, I love the stuff. There are some pretty handy sizes available from stock and custom sizes are available. I want to machine a base, column and table from stock. If this works out, I may make some "kits" consisting of the above for those looking to build a milling machine or lathe. Let me know what you think...
www.dura-bar.com
Old 09-29-2007, 03:44 AM
Bump
Old 09-29-2007, 01:17 PM
yugami is on a distinguished road
I have zero personal experience.
I just wanted to say that I've heard of it though other discussions where it was recommended.
To quote one guy (Errol Groth) from rec.crafts.metalworking on usenet:
"so I settled for the Dura Bar.
Which by the way is just lovely stuff to machine. Not a hard spot or
void in it at all. "
He said settled for because he was thinking of casting it himself.
The project he was discussing is here:
http://neme-s.org/SB_Carriage_Stop/m...riage_stop.htm
Old 09-30-2007, 06:13 PM
My personal experience with Durabar continuous cast bar has been nothing but EXCELENT. I have no interest in that company whatsoever except as an appreciative customer. For 1-off parts made from cast iron (or?) works great.
DZASTR
Old 09-30-2007, 06:21 PM
Thanks guys. This is the kind of feedback I was looking for. The fact that this stuff can be heat-treated and precision ground after machining to size is an added bonus. Especially for parts like machine tables and bases. Machine to size, heat-treat, harden and grind for the linear ways...machine t-slots, harden and grind the table for use.
Old 10-16-2007, 12:48 PM
sc brian is on a distinguished road
Durabar is nice stuff, not cheap
I have built machine tools out of Durabar. It machines quite well and is stable and well damped. The only downside is that it is not cheap.
Another trick: buy Durabar tubes, bolt them together into machine structures, and fill the tubes with epoxy-granite, lead shot, or even sand! Structure will be very well damped.
Linear components for new machine 307startup Linear and Rotary Motion 6 11-06-2006 12:58 PM
Now Available - All your Machine / Transmission Components 0lux0 Product Announcements & Manufacturer News 2 02-24-2006 09:35 AM
Learning from scratch Kitch02 General CNC (Mill and Lathe) Control Software (NC) 2 03-22-2005 07:00 AM
Fax Machine For Power Supply Components? FLUTE HEAD General Electronics Discussion 1 08-03-2004 06:08 PM
